[cgma-dev] r5165 - cgm/trunk/geom/parallel
hongjun at mcs.anl.gov
Fri Sep 16 13:31:35 CDT 2011
Author: hongjun
Date: 2011-09-16 13:31:34 -0500 (Fri, 16 Sep 2011)
New Revision: 5165
Modified:
cgm/trunk/geom/parallel/CABodies.cpp
cgm/trunk/geom/parallel/CGMReadParallel.cpp
cgm/trunk/geom/parallel/TDParallel.cpp
cgm/trunk/geom/parallel/TDParallel.hpp
Log:
o more changes to add ghost geomtry entity info in CABodies and TDParallel
o passes make check
Modified: cgm/trunk/geom/parallel/CABodies.cpp
--- cgm/trunk/geom/parallel/CABodies.cpp 2011-09-15 22:00:51 UTC (rev 5164)
+++ cgm/trunk/geom/parallel/CABodies.cpp 2011-09-16 18:31:34 UTC (rev 5165)
@@ -149,7 +149,7 @@
else {
// else make a new one
par = new TDParallel(attrib_owner(), &m_sharedBodies, &m_sharedProcs,
- m_uniqueID, m_interface);
+ &m_ghostProcs, m_uniqueID, m_interface);
delete_attrib(CUBIT_TRUE);
Modified: cgm/trunk/geom/parallel/CGMReadParallel.cpp
--- cgm/trunk/geom/parallel/CGMReadParallel.cpp 2011-09-15 22:00:51 UTC (rev 5164)
+++ cgm/trunk/geom/parallel/CGMReadParallel.cpp 2011-09-16 18:31:34 UTC (rev 5165)
@@ -506,7 +506,7 @@
shared_procs.reverse();
loads[shared_procs[0]] = loads[shared_procs[0]] + entity->measure();
- td_par = new TDParallel(entity, NULL, &shared_procs, merge_id, 1);
+ td_par = new TDParallel(entity, NULL, &shared_procs, NULL, merge_id, 1);
else if (entity->entity_type_info() == typeid(RefEdge) ||
entity->entity_type_info() == typeid(RefVertex)) {
@@ -533,7 +533,7 @@
Modified: cgm/trunk/geom/parallel/TDParallel.cpp
--- cgm/trunk/geom/parallel/TDParallel.cpp 2011-09-15 22:00:51 UTC (rev 5164)
+++ cgm/trunk/geom/parallel/TDParallel.cpp 2011-09-16 18:31:34 UTC (rev 5165)
@@ -15,8 +15,8 @@
#include <time.h>
TDParallel::TDParallel(ToolDataUser *owner, DLIList<int> *shared_bodies,
- DLIList<int> *shared_procs, int unique_id,
- int interface)
+ DLIList<int> *shared_procs, DLIList<int> *ghost_procs,
+ int unique_id, int interface)
: m_uniqueId(unique_id), m_interface(interface)
More information about the cgma-dev
