[cgma-dev] [Fathom] cgm make check with occ
Jiangtao Hu
jiangtao_ma at yahoo.com
Fri Sep 16 10:41:48 CDT 2011
Hi, Iulian,
I went to gnep and double checked the test failure for modify.cpp. The reason for it is that it didn't apply patch
https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk/geom/OCC/occ_patches_6.5
correctly.
I don't have write permission on it, but the file
OpenCascade6.5.0/ros/src/BRepBuilderAPI/BRepBuilderAPI_Collect.cxx wasn't patched.
You should get the failure away when you apply this patch and rebuild OCC.
Please let me know if it's not. I'll be looking into occ6.3 build then.
Thanks.
Jane
--- On Thu, 9/15/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
Subject: Re: [Fathom] cgm make check with occ
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>, "James Porter" <jvporter at wisc.edu>
Date: Thursday, September 15, 2011, 2:02 PM
Hi Jane,
So maybe the occ build is wrong
I built occ 6.5 on fathom space:
/home/fathom/3rdparty/occ/OpenCASCADE6.5.0
the configuration log file is here:
home/fathom/3rdparty/occ/OpenCASCADE6.5.0/ros/config.log
The installation is at
/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc
It was built on my desktop, iulian-desktop
gnep buildbot is using the same build
Do you have an mcs account? Otherwise how can you access my machine ? Or gnep?
Iulian
----- Original Message -----
> Hi, Iulian,
> What is the build machine's name? I tried to use non-debug mode on my
> machine, it still passed. I'd like to access your machine to debug
> then. Thanks.
> Jane
> From: Iulian Grindeanu <iulian at mcs.anl.gov>
> Date: Thursday, September 15, 2011, 1:01 PM
> > Hi, Iulian,
> > Those missing files are only for 10.2 cgm, 12.2 cgm has already have
> > them. Can you let me know where the modify failed? Thanks.
> > Is the nightly build and check for cgm still on? Can James confirm
> > it?
> > Thanks.
> > Jane
> > --- On Thu, 9/15/11, Iulian Grindeanu < iulian at mcs.anl.gov > wrote:
> Hi Jane,
> The backtrace is
> (gdb) backtrace
> #0 0x00007fffee5c5a75 in *__GI_raise (sig=<value optimized out>) at
> ../nptl/sysdeps/unix/sysv/linux/raise.c:64
> #1 0x00007fffee5c95c0 in *__GI_abort () at abort.c:92
> #2 0x00007ffff00378e5 in __gnu_cxx::__verbose_terminate_handler() ()
> from /usr/lib/libstdc++.so.6
> #3 0x00007ffff0035d16 in ?? () from /usr/lib/libstdc++.so.6
> #4 0x00007ffff0035d43 in std::terminate() () from
> #5 0x00007ffff0035e3e in __cxa_throw () from /usr/lib/libstdc++.so.6
> #6 0x00007ffff03446ed in Standard_NoSuchObject::Throw() const () from
> /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so.0
> #7 0x00007ffff0344bc3 in Standard_NoSuchObject::Raise(char const*) ()
> from
> #8 0x00007ffff232d78d in
> BRepBuilderAPI_ModifyShape::ModifiedShape(TopoDS_Shape const&) const
> () from
> /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so.0
> #9 0x00007ffff231cd43 in
> BRepBuilderAPI_GTransform::ModifiedShape(TopoDS_Shape const&) const ()
> from
> #10 0x000000000043c6aa in OCCLump::update_OCC_entity (this=0xcce470,
> aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCLump.cpp:378
> #11 0x000000000042de01 in OCCBody::update_OCC_entity (this=0xcd40e0,
> aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCBody.cpp:511
> #12 0x000000000042da4d in OCCBody::scale (this=0xcd40e0,
> scale_factor_x=1, scale_factor_y=2, scale_factor_z=5) at
> OCCBody.cpp:450
> #13 0x00000000004556da in OCCQueryEngine::scale (this=0xcc14c0,
> body=0xcd40e0, f=...) at OCCQueryEngine.cpp:3516
> #14 0x00000000004870ce in OCCModifyEngine::scale (this=0xcc1600,
> body=@0x7fffffffd0b0, factors=...) at OCCModifyEngine.cpp:8891
> #15 0x00000000006ea8c2 in GeometryModifyTool::scale (this=0xcbefd0,
> body=@0x7fffffffe1c8, factors=..., check_to_transform=true,
> preview=false) at GeometryModifyTool.cpp:6779
> #16 0x0000000000421345 in make_Point () at modify.cpp:146
> #17 0x0000000000420b0f in main (argc=1, argv=0x7fffffffe3c8) at
> modify.cpp:55
> occ 6.5 is not build with debug option on our machines, so it is
> harder to debug.
> Do you build occ with "enable-debug" on your machine?
> Iulian
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110916/ccb858b5/attachment.htm>
More information about the cgma-dev
