[cgma-dev] [Fathom] cgm make check with occ
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Thu Sep 15 12:17:22 CDT 2011
Hi, Iulian,
What is the build machine's name? I tried to use non-debug mode on my machine, it still passed. I'd like to access your machine to debug then. Thanks.
Jane
--- On Thu, 9/15/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
Subject: Re: [Fathom] cgm make check with occ
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>, "James Porter" <jvporter at wisc.edu>
Date: Thursday, September 15, 2011, 1:01 PM
----- Original Message -----
> Hi, Iulian,
> Those missing files are only for 10.2 cgm, 12.2 cgm has already have
> them. Can you let me know where the modify failed? Thanks.
> Is the nightly build and check for cgm still on? Can James confirm it?
> Thanks.
> Jane
Hi Jane,
The backtrace is
(gdb) backtrace
#0  0x00007fffee5c5a75 in *__GI_raise (sig=<value optimized out>) at ../nptl/sysdeps/unix/sysv/linux/raise.c:64
#1  0x00007fffee5c95c0 in *__GI_abort () at abort.c:92
#2  0x00007ffff00378e5 in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/libstdc++.so.6
#3  0x00007ffff0035d16 in ?? () from /usr/lib/libstdc++.so.6
#4  0x00007ffff0035d43 in std::terminate() () from /usr/lib/libstdc++.so.6
#5  0x00007ffff0035e3e in __cxa_throw () from /usr/lib/libstdc++.so.6
#6  0x00007ffff03446ed in Standard_NoSuchObject::Throw() const () from /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so.0
#7  0x00007ffff0344bc3 in Standard_NoSuchObject::Raise(char const*) () from /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so.0
#8  0x00007ffff232d78d in BRepBuilderAPI_ModifyShape::ModifiedShape(TopoDS_Shape const&) const () from /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so.0
#9  0x00007ffff231cd43 in BRepBuilderAPI_GTransform::ModifiedShape(TopoDS_Shape const&) const () from /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so.0
#10 0x000000000043c6aa in OCCLump::update_OCC_entity (this=0xcce470, aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCLump.cpp:378
#11 0x000000000042de01 in OCCBody::update_OCC_entity (this=0xcd40e0, aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCBody.cpp:511
#12 0x000000000042da4d in OCCBody::scale (this=0xcd40e0, scale_factor_x=1, scale_factor_y=2, scale_factor_z=5) at OCCBody.cpp:450
#13 0x00000000004556da in OCCQueryEngine::scale (this=0xcc14c0, body=0xcd40e0, f=...) at OCCQueryEngine.cpp:3516
#14 0x00000000004870ce in OCCModifyEngine::scale (this=0xcc1600, body=@0x7fffffffd0b0, factors=...) at OCCModifyEngine.cpp:8891
#15 0x00000000006ea8c2 in GeometryModifyTool::scale (this=0xcbefd0, body=@0x7fffffffe1c8, factors=..., check_to_transform=true, preview=false) at GeometryModifyTool.cpp:6779
#16 0x0000000000421345 in make_Point () at modify.cpp:146
#17 0x0000000000420b0f in main (argc=1, argv=0x7fffffffe3c8) at modify.cpp:55
occ 6.5 is not build with debug option on our machines, so it is harder to debug.
Do you build occ with "enable-debug" on your machine?
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110915/cf80b686/attachment-0001.htm>
More information about the cgma-dev
