[cgma-dev] r5105 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Thu Aug 18 10:10:29 CDT 2011
Author: janehu
Date: 2011-08-18 10:10:29 -0500 (Thu, 18 Aug 2011)
New Revision: 5105
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Fix for ilc_13body.stp case with 2 coedges in one loop, provided by Hong-Jun.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-08-15 19:14:18 UTC (rev 5104)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-08-18 15:10:29 UTC (rev 5105)
@@ -2080,6 +2080,55 @@
CubitVector normal;
occ_surface->get_point_normal(center, normal);
+ //number of coedges = 2 case is checked here.
+ //make sure the normal get from the cross product of the two
+ //coedges are the same as the normal.
+ DLIList<OCCCoEdge*> codeges;
+ occ_surface->get_coedges(codeges);
+ if(codeges.size() == 2 && occ_surface->measure() > 0.000001)
+ OCCCoEdge* coedge1 = codeges.get_and_step();
+ OCCCoEdge* coedge2 = codeges.get();
+ OCCCurve* curve1 = CAST_TO(coedge1->curve(), OCCCurve);
+ OCCCurve* curve2 = CAST_TO(coedge2->curve(), OCCCurve);
+ double d1 = curve1->measure();
+ double d2 = curve2->measure();
+ double start1 = curve1->start_param();
+ double start2 = curve2->start_param();
+ double u1, u2;
+ if (coedge1->sense() == CUBIT_REVERSED)
+ u1 = curve1->u_from_arc_length(start1, d1*0.05);
+ else
+ u1 = curve1->u_from_arc_length(start1, d1*0.95);
+ if (coedge2->sense() == CUBIT_REVERSED)
+ u2 = curve2->u_from_arc_length(start2, d2 * 0.95);
+ else
+ u2 = curve2->u_from_arc_length(start2, d2*0.05);
+ CubitVector v1, v2, v_cross;
+ double d_dot;
+ curve1->position_from_u(u1,v1);
+ curve2->position_from_u(u2,v2);
+ CubitVector tangent1, tangent2;
+ curve1->get_tangent(v1, tangent1);
+ curve2->get_tangent(v2, tangent2);
+ tangent1 *= -1;
+ tangent2 *= -1;
+ v_cross = tangent1 * tangent2;
+ if (v_cross.length() > 0.000001)
+ d_dot = v_cross % normal;
+ if (d_dot < 0)
+ //Reverse all coedges' senses.
+ CubitSense sense = (coedge1->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
More information about the cgma-dev
