[cgma-dev] r5088 - cgm/trunk/geom/OCC
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Mon Aug 15 16:06:57 CDT 2011
Thank you for your fix.
It works for most test geometries except the one with merged entities.
It looks there are wrong merged edge directions respect to parent surfaces.
I am trying to make a test code for this, but before that, can you think any suspected code for this problem?
Thanks.
Hong-Jun Kim
Post-doc researcher
MCS, Argonne National Laboratory
9700 S. Cass Ave. B240/R2147
Argonne, IL 60439
630-252-4791
----- Original Message -----
To: "Jane Hu" <janejhu at gmail.com>, "Hong-Jun Kim" <hongjun at mcs.anl.gov>
Cc: cgma-dev at mcs.anl.gov
Sent: Monday, August 15, 2011 12:32:21 PM
Subject: Re: [cgma-dev] r5088 - cgm/trunk/geom/OCC
Hi, Hong-Jun,
Please see r5102 for fix of your model. Thanks for fixing the nightly build issues.
Jane
Cc: cgma-dev at mcs.anl.gov, "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Date: Friday, August 12, 2011, 5:53 PM
Hi, Jane
Could you please check the attached step file for "test_edge_orient" again?
4 similar shaped faces have problems in the test with OCC kernel.
Thanks.
Hong-Jun Kim
Post-doc researcher
Argonne, IL 60439
630-252-4791
To: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
Cc: "Hong-Jun Kim" < hongjun at mcs.anl.gov >, cgma-dev at mcs.anl.gov
Sent: Friday, August 12, 2011 12:31:22 PM
Hi, Hong-Jun
Please use r5098 to fix the problem seen in your model. Thanks.
Jane
On Thu, Aug 11, 2011 at 10:58 PM, Jiangtao Hu < jiangtao_ma at yahoo.com > wrote:
Sure, I'll look into this case tomorrow. Thanks for the model and your time finding it.
Jane
To: jiangtao_ma at yahoo.com
Date: Thursday, August 11, 2011, 5:12 PM
Hi, jane
I attached a step geometry file (with a picture) having problem in OCC kernel.
It passes the "test_edge_orient" in ACIS kernel but doesn't in OCC.
Could you please check this file?
Thanks.
Hong-Jun
To: cgma-dev at mcs.anl.gov
Sent: Thursday, August 11, 2011 3:06:25 PM
Thank you for this change.
I am testing it with complex geometries and it looks there are some improvement but it is not working for some cases.
I am still finding where the problem is coming from and let me inform you the result.
Thanks.
Hong-Jun
> From: "jiangtao ma" < jiangtao_ma at yahoo.com >
> Sent: Thursday, August 11, 2011 9:21:55 AM
> Subject: [cgma-dev] r5088 - cgm/trunk/geom/OCC
> Author: janehu
> Date: 2011-08-11 09:21:55 -0500 (Thu, 11 Aug 2011)
> New Revision: 5088
> Modified:
> cgm/trunk/geom/OCC/OCCCurve.cpp
> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> cgm/trunk/geom/OCC/OCCSurface.cpp
> Log:
> Added changes to make coedge and loop direction correct. For surfaces,
> opposite to acis where face is always forward direction respect to its
> volume, OCC surfaces and shell might be reversed direction with
> respect to its solid. This may cause volume mesh fail, I am looking
> into it now, and might need to change some logic in the geom level of
> cgm.
> Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
> --- cgm/trunk/geom/OCC/OCCCurve.cpp 2011-08-09 22:27:32 UTC (rev 5087)
> +++ cgm/trunk/geom/OCC/OCCCurve.cpp 2011-08-11 14:21:55 UTC (rev 5088)
> @@ -123,10 +123,10 @@
> void OCCCurve::set_TopoDS_Edge(TopoDS_Edge edge)
> - if(edge.IsEqual(*myTopoDSEdge))
> + if(edge.IsSame(*myTopoDSEdge))
> return;
> - if(!edge.IsSame(*myTopoDSEdge))
> + else
> DLIList<OCCPoint*> points ;
> this->get_points(points);
> @@ -737,8 +737,7 @@
> double OCCCurve::start_param()
> double start = 0.0, end = 0.0;
> - get_param_range( start, end );
> + get_param_range( start, end );
> return start;
> @@ -781,29 +780,22 @@
> TopTools_IndexedMapOfShape M;
> TopExp::MapShapes(*myTopoDSEdge, TopAbs_VERTEX, M);
> - TopologyBridge *point1, *point2;
> - if (M.Extent()==1) {
> - point1 = OCCQueryEngine::instance()->occ_to_cgm(M(1));
> - if (point1)
> - children.append_unique(point1);
> - } else if (M.Extent()==2) {
> - if ( fabs(BRep_Tool::Parameter(TopoDS::Vertex(M(1)),
> *myTopoDSEdge)-start_param()) >
> - fabs(BRep_Tool::Parameter(TopoDS::Vertex(M(2)),
> *myTopoDSEdge)-start_param()) ) {
> - point1 = OCCQueryEngine::instance()->occ_to_cgm(M(2));
> - point2 = OCCQueryEngine::instance()->occ_to_cgm(M(1));
> - } else {
> - point2 = OCCQueryEngine::instance()->occ_to_cgm(M(2));
> - if (point1 && point1 == point2) {
> - } else {
> - if (point1)
> - if (point2)
More information about the cgma-dev
