[cgma-dev] r5102 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Mon Aug 15 12:27:13 CDT 2011
Author: janehu
Date: 2011-08-15 12:27:12 -0500 (Mon, 15 Aug 2011)
New Revision: 5102
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Replaced tolerance check for connecting vertices in loop direction check by comparing forward and reversed direction vertices distance to better handle model tolerance problem. Added model file in itap dir.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-08-13 19:15:27 UTC (rev 5101)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-08-15 17:27:12 UTC (rev 5102)
@@ -2328,22 +2328,39 @@
if(coedges_new.size() > 1)
OCCCoEdge* coedge = coedges_new.get_and_step();
- double d1, d2;
+ double d1, d1_, d2, d2_;
OCCCoEdge* next_coedge = coedges_new.get();
+ //because of tolerance issue, now check current loop end vertices distance
+ //compared with reversed loop's end vertices distance, which ever shorter
+ //will be the direction.
+ //current loop's parameter not using " _ ", reversed loop's parameter
+ //uses " _ ".
if (coedge->sense() == CUBIT_FORWARD)
d1 = coedge->curve()->end_param();
+ d1_ = coedge->curve()->start_param();
else
d1 = coedge->curve()->start_param();
+ d1_ = coedge->curve()->end_param();
if( next_coedge->sense() == CUBIT_FORWARD)
+ d2_ = next_coedge->curve()->end_param();
d2 = next_coedge->curve()->start_param();
else
d2 = next_coedge->curve()->end_param();
- CubitVector v1, v2;
+ d2_ = next_coedge->curve()->start_param();
+ CubitVector v1, v1_, v2, v2_;
coedge->curve()->position_from_u(d1, v1);
+ coedge->curve()->position_from_u(d1_, v1_);
next_coedge->curve()->position_from_u(d2, v2);
- //get_sme_resabs_tolerance() = 1*10^-7, while the distance difference
- //we consider would be 1*10^-6.
- if(v1.distance_between(v2) > get_sme_resabs_tolerance()*10)
+ next_coedge->curve()->position_from_u(d2_, v2_);
+ if(v1.distance_between(v2) > v1_.distance_between(v2_))
//Reverse all coedges' senses.
for (int i = 0; i < coedges_new.size(); i ++)
More information about the cgma-dev
