[cgma-dev] r5090 - cgm/trunk/test
jiangtao_ma at yahoo.com
Thu Aug 11 09:23:35 CDT 2011
Author: janehu
Date: 2011-08-11 09:23:35 -0500 (Thu, 11 Aug 2011)
New Revision: 5090
Modified:
cgm/trunk/test/makept.cpp
cgm/trunk/test/modify.cpp
Log:
Changes coresponding to r5088. Passed all tests in cgm.
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2011-08-11 14:22:46 UTC (rev 5089)
+++ cgm/trunk/test/makept.cpp 2011-08-11 14:23:35 UTC (rev 5090)
@@ -524,7 +524,7 @@
RefEdge* edge1 = ref_edges1->pop();
RefEdge* edge2 = ref_edges1->pop();
double angle = edge2->angle_between(edge1, ref_face);
- assert(fabs(angle - 4.712) < 0.001);
+ assert(fabs(angle - 1.5707) < 0.001);
//test for curve
CubitVector c_point, tangent, center;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2011-08-11 14:22:46 UTC (rev 5089)
+++ cgm/trunk/test/modify.cpp 2011-08-11 14:23:35 UTC (rev 5090)
@@ -139,7 +139,8 @@
assert(fabs(volume-1000) <= 0.00001);
n = all_bodies.get()->num_ref_faces();
assert(n == 6);
+ body = all_bodies.get();
Body* body2 = gmti->brick(10, 10, 10);
CubitVector scale(1, 2, 5);
gmti->scale(body2, scale);
@@ -188,7 +189,7 @@
away *= 3;
gti->translate(tweak_body, away);
away /= 3;
- CubitVector delta(0,-1,0);
+ CubitVector delta(-1, 0, 0);
DLIList<Body*> tweak_bodies;
gmti->tweak_move( tweak_edges, delta, tweak_bodies, CUBIT_FALSE,
CUBIT_FALSE);
More information about the cgma-dev
