[cgma-dev] r5066 - cgm/trunk/geom/OCC
Rajeev Jain
jain at mcs.anl.gov
Thu Jul 21 12:30:26 CDT 2011
Thanks, Jane.
Rajeev
>________________________________
>From: "jiangtao_ma at yahoo.com" <jiangtao_ma at yahoo.com>
>To: cgma-dev at mcs.anl.gov
>Sent: Thursday, July 21, 2011 11:18 AM
>Subject: [cgma-dev] r5066 - cgm/trunk/geom/OCC
>Author: janehu
>Date: 2011-07-21 11:18:05 -0500 (Thu, 21 Jul 2011)
>New Revision: 5066
>Modified:
> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.hpp
>Log:
>Changed unite function to correctly check bounding box intersection, and supporting other code change. Improved rgg/assygen for 7.inp from 3173s to 104 seconds. Passed make check for cgm.
>Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
>--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2011-07-19 17:57:32 UTC (rev 5065)
>+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2011-07-21 16:18:05 UTC (rev 5066)
>@@ -2195,6 +2195,7 @@
> //indicate if there's more faces to be imprinted
> CubitBoolean more_face = CUBIT_TRUE;
> DLIList<TopoDS_Face*> list_for_delete;
>+ CubitBoolean face_created = CUBIT_FALSE;
> //list of face on from_shape that has been imprinted
> DLIList<TopoDS_Face*> from_faces;
>@@ -2409,7 +2410,10 @@
> face = (OCCSurface*)(OCCQueryEngine::instance()->OccToCGM->find(i))->second;
> else
>+ face_created = CUBIT_TRUE;
> face = OCCQueryEngine::instance()->populate_topology_bridge(from_face);
> OCCSurface* occ_face = CAST_TO(face, OCCSurface);
> DLIList<Curve*> common_curves;
>@@ -2494,6 +2498,7 @@
> CubitVector point_on_surf;
> occ_face->closest_point_trimmed(p, point_on_surf);
> if(p.distance_between(point_on_surf) > TOL) //edge not on from_face
> skipped = CUBIT_TRUE;
>@@ -2553,7 +2558,7 @@
> added = CUBIT_TRUE;
> curve_list.append(curve);
> if(added)
> topo_changed = CUBIT_TRUE;
>@@ -2591,7 +2596,12 @@
>+ if(face_created)
>+ OCCQueryEngine::instance()->delete_solid_model_entities(occ_face);
>+ face_created = CUBIT_FALSE;
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110721/85a60656/attachment.htm>
More information about the cgma-dev
