[cgma-dev] r5061 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Jul 15 12:28:55 CDT 2011
Author: janehu
Date: 2011-07-15 12:28:55 -0500 (Fri, 15 Jul 2011)
New Revision: 5061
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
To avoid unnecessary binding of the TopoShape, directly set the new_shape in the Shape_Label_Map, fixed assygen failure problem in meshkit/rgg.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-07-15 14:21:12 UTC (rev 5060)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-07-15 17:28:55 UTC (rev 5061)
@@ -3594,8 +3594,14 @@
     return -1;
   //update the attribute label tree
-  copy_attributes(old_shape, new_shape);
-  OCCAttribSet::remove_attribute(old_shape);
+  int current_id = OCCMap->Find(old_shape);
+  std::map<int, TDF_Label>::iterator it_lab =
+          Shape_Label_Map->find(current_id);
+  if(it_lab != Shape_Label_Map->end())
+     TDF_Label aLabel = (*it_lab).second;
+     Handle_TDataXtd_Shape attr_shape = TDataXtd_Shape::Set(aLabel, new_shape);
   //update CGM-OCC map
   int k = OCCMap->Find(old_shape);
More information about the cgma-dev mailing list
