[cgma-dev] r5052 - cgm/trunk/test
    Jane Hu
    janejhu at gmail.com
    Tue Jul 12 12:59:18 CDT 2011
I'll look into it. Currently I found the single lump body attribute seems
lost, other ids are all kept. I'll look into details. Thanks.
Jane
On Tue, Jul 12, 2011 at 12:23 PM, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
> This seems not checked if attributes are really restored after importing
> geometry again.
> I think entity ids have to be checked restored correctly.
> Hong-Jun
> From: "jiangtao ma" <jiangtao_ma at yahoo.com>
> To: cgma-dev at mcs.anl.gov
> Sent: Tuesday, July 12, 2011 11:55:15 AM
> Subject: [cgma-dev] r5052 - cgm/trunk/test
> Author: janehu
> Date: 2011-07-12 11:55:15 -0500 (Tue, 12 Jul 2011)
> New Revision: 5052
> Modified:
>   cgm/trunk/test/attribute_to_buffer.cpp
>   cgm/trunk/test/attribute_to_file.cpp
>   cgm/trunk/test/makept.cpp
>   cgm/trunk/test/modify.cpp
> Log:
> Remove parallel test from attribute export tests; minor updates for modify
> and makept.
> Modified: cgm/trunk/test/attribute_to_buffer.cpp
> --- cgm/trunk/test/attribute_to_buffer.cpp      2011-07-11 20:23:21 UTC
> (rev 5051)
> +++ cgm/trunk/test/attribute_to_buffer.cpp      2011-07-12 16:55:15 UTC
> (rev 5052)
> @@ -4,10 +4,10 @@
>  #include "Body.hpp"
>  #include "CGMApp.hpp"
>  #include "CubitAttribManager.hpp"
> -#include "CADefines.hpp"
> -#include "TDParallel.hpp"
> -#include "CABodies.hpp"
> +#include "CAEntityId.hpp"
> +#include <iostream>
> +#include <string>
>  #include <stdio.h>
>  #include <stdlib.h>
> @@ -37,8 +37,8 @@
>   ASSERT(s);
>   // actuate CA_BODIES attribute and turn on auto flag
> -  CGMApp::instance()->attrib_manager()->register_attrib_type(CA_BODIES,
> "bodies", "BODIES",
>  CABodies_creator, CUBIT_TRUE,
> +  CGMApp::instance()->attrib_manager()->register_attrib_type(CA_ENTITY_ID,
> "id", "ENTITY_ID",
>  CAEntityId_creator, CUBIT_TRUE,
>                                                             CUBIT_TRUE,
> CUBIT_TRUE, CUBIT_TRUE,
>                                                             CUBIT_TRUE,
> CUBIT_FALSE);
>   CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE);
> @@ -53,24 +53,6 @@
>     s = GeometryQueryTool::instance()->translate( bricks[i],
> CubitVector(i,0,0) );
>     ASSERT(s);
>     export_list.append( bricks[i] );
> -    // add tool data to bodies
> -    RefEntity* entity = dynamic_cast<RefEntity*> (bricks[i]);
> -    DLIList<int> shared_procs;
> -    shared_procs.append(i);
> -    TDParallel *td_par = (TDParallel *)
> entity->get_TD(&TDParallel::is_parallel);
> -    if (td_par == NULL) td_par = new TDParallel(entity, NULL,
> &shared_procs);
> -    // add tool data to volumes too
> -    DLIList<RefVolume*> volumes;
> -    (dynamic_cast<TopologyEntity*> (entity))->ref_volumes(volumes);
> -    int n_vol = volumes.size();
> -    volumes.reset();
> -    for (int j = 0; j < n_vol; j++) {
> -      RefEntity *vol = volumes.get_and_step();
> -      td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
> -      if (td_par == NULL) td_par = new TDParallel(vol, NULL,
> &shared_procs);
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110712/96b96746/attachment.htm>
More information about the cgma-dev
