[cgma-dev] r5052 - cgm/trunk/test
jiangtao_ma at yahoo.com
Tue Jul 12 11:55:15 CDT 2011
Author: janehu
Date: 2011-07-12 11:55:15 -0500 (Tue, 12 Jul 2011)
New Revision: 5052
Modified:
cgm/trunk/test/attribute_to_buffer.cpp
cgm/trunk/test/attribute_to_file.cpp
cgm/trunk/test/makept.cpp
cgm/trunk/test/modify.cpp
Log:
Remove parallel test from attribute export tests; minor updates for modify and makept.
Modified: cgm/trunk/test/attribute_to_buffer.cpp
--- cgm/trunk/test/attribute_to_buffer.cpp 2011-07-11 20:23:21 UTC (rev 5051)
+++ cgm/trunk/test/attribute_to_buffer.cpp 2011-07-12 16:55:15 UTC (rev 5052)
@@ -4,10 +4,10 @@
#include "Body.hpp"
#include "CGMApp.hpp"
#include "CubitAttribManager.hpp"
-#include "CADefines.hpp"
-#include "TDParallel.hpp"
-#include "CABodies.hpp"
+#include "CAEntityId.hpp"
+#include <iostream>
+#include <string>
#include <stdio.h>
#include <stdlib.h>
@@ -37,8 +37,8 @@
ASSERT(s);
// actuate CA_BODIES attribute and turn on auto flag
- CGMApp::instance()->attrib_manager()->register_attrib_type(CA_BODIES, "bodies", "BODIES",
- CABodies_creator, CUBIT_TRUE,
+ CGMApp::instance()->attrib_manager()->register_attrib_type(CA_ENTITY_ID, "id", "ENTITY_ID",
+ CAEntityId_creator, CUBIT_TRUE,
CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
CUBIT_TRUE, CUBIT_FALSE);
CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE);
@@ -53,24 +53,6 @@
s = GeometryQueryTool::instance()->translate( bricks[i], CubitVector(i,0,0) );
ASSERT(s);
export_list.append( bricks[i] );
- // add tool data to bodies
- RefEntity* entity = dynamic_cast<RefEntity*> (bricks[i]);
- DLIList<int> shared_procs;
- shared_procs.append(i);
- TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
- if (td_par == NULL) td_par = new TDParallel(entity, NULL, &shared_procs);
- // add tool data to volumes too
- DLIList<RefVolume*> volumes;
- (dynamic_cast<TopologyEntity*> (entity))->ref_volumes(volumes);
- int n_vol = volumes.size();
- volumes.reset();
- for (int j = 0; j < n_vol; j++) {
- RefEntity *vol = volumes.get_and_step();
- td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
- if (td_par == NULL) td_par = new TDParallel(vol, NULL, &shared_procs);
More information about the cgma-dev
