[cgma-dev] Version issue with nightly build
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Jun 21 13:00:09 CDT 2011
Since we've released 12.2 now, shouldn't it be 13.0pre?
- tim
On 06/21/2011 12:52 PM, James Porter wrote:
> On Tue, 2011-06-21 at 12:36 -0500, Steve Jackson wrote:
>> Although the nightly build tarball linked from the CGMA website appears to contain code for the latest version of CGM, it's still being distributed as version 10.2.3.  Can somebody run autoreconf on it?
>> (tarball link : http://gnep.mcs.anl.gov:8010/cgm-nightly.tar.gz )
>> ~S
> Autoreconf (should) be run on every build; it seems that configure.ac
> still lists the version as 10.2.3, which is probably wrong. For one
> thing, our current policy is that the version numbers for trunk/branches
> should be of the form "1.2.3pre". Should I update this to, say,
> 12.0.0pre?
> - Jim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
