[cgma-dev] r5024 - cgm/trunk/geom/OCC
hongjun at mcs.anl.gov
Mon Jun 20 12:22:03 CDT 2011
Author: hongjun
Date: 2011-06-20 12:22:00 -0500 (Mon, 20 Jun 2011)
New Revision: 5024
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
o "read" and "write" from/to buffer functions are reverted to use buffers directly
o passes make check
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-06-17 20:29:32 UTC (rev 5023)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2011-06-20 17:22:00 UTC (rev 5024)
@@ -1366,29 +1366,26 @@
bool b_write_buffer,
TDF_Label label)
- Standard_CString file_name = "tempfile";
- if(!Write(Sh, const_cast<char*>(file_name),label))
- return CUBIT_FAILURE;
+ // make buffer as ouput stream
+ std::stringbuf sb;
+ std::iostream os(&sb);
+ OCCShapeAttributeSet SS;
+ // write to output stream
+ SS.Add(Sh);
+ os << "DBRep_DrawableShape\n"; // for easy Draw read
+ SS.Write(os);
+ CubitBoolean isGood = os.good();
+ if (!isGood) return isGood;
+ SS.Write(Sh,os,&label);
+ isGood = os.good();
+ n_buffer_size = os.rdbuf()->pubseekoff(0, std::ios_base::end, std::ios::out);
- // get size of file
- ifstream infile (file_name, ifstream::binary);
- infile.seekg(0,ifstream::end);
- long size=infile.tellg();
- infile.seekg(0);
- if (b_write_buffer) {
- if(n_buffer_size < size) {
- PRINT_ERROR("Buffer size is not enough, increase buffer size.\n");
- infile.close();
- remove(file_name);
- infile.read(pBuffer,size);
- else n_buffer_size = size;
- infile.close();
+ // get real geometries from output stream to buffer
+ if (b_write_buffer) os.read(pBuffer, n_buffer_size);
return CUBIT_TRUE;
More information about the cgma-dev
