[cgma-dev] Use ACIS classes and api functions through CUBIT
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Mon Jun 13 09:45:52 CDT 2011
Thank you very much for your reply.
Of course, I can wait your work.
Hong-Jun
----- Original Message -----
> From: "Jane Hu" <janejhu at gmail.com>
> To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> Cc: cgma-dev at mcs.anl.gov
> Sent: Monday, June 13, 2011 9:41:51 AM
> Subject: Re: [cgma-dev] Use ACIS classes and api functions through CUBIT
> Hi, Hong-Jun
> I am now working on OCC performance issues, and did find that
> attribute save takes long times, and I am still working on a fix for
> it. Give me one more week to see if I have any clue on it while you
> are thinking about using ACIS, and I'll let you know how OCC can do on
> this matter for you.
> Good luck!
> Jane
> On Fri, Jun 10, 2011 at 5:36 PM, Hong-Jun Kim < hongjun at mcs.anl.gov >
> wrote:
> Hi, all
> I am using OCC geometry kernel for parallel meshing, but it takes too
> long time to import and export large size of geometry with attribute
> information.
> For example, it takes over 1 hour for merged "vhtr" geometry(327
> bodies) to be distributed to processors.
> This makes our parallel mesh tool not so practical in real world
> problem, then I am thinking use ACIS kernel instead through cubit
> library.
> For this, I need to use some ACIS classes and api functions such as
> "BinaryFile" and "api_save_entity_list_file" and then, is there any
> way to use these from cubit library?
> I am wondering if I can make and use some dummy header files similar
> to "NoAcisQueryEngine.hpp" to solve this problem.
> Thanks.
> Hong-Jun
More information about the cgma-dev
