[cgma-dev] CGM/itaps/testgeom_occ
    Jane Hu
    janejhu at gmail.com
    Thu Jun  9 11:53:49 CDT 2011
Ok, I didn't update the testcase, now it did fail, and your change looks
proper. please go ahead to add it .
Thanks.
Jane
On Thu, Jun 9, 2011 at 10:52 AM, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
> By the way, I am curious why you don't fail the test.
> Inside "faceting_test", when "size.sat" is imported to OCC geometry kernel,
> it looks it must fail.
> Am I wrong?
> Hong-Jun
> From: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> To: "Jane Hu" <janejhu at gmail.com>
> Cc: cgma-dev at mcs.anl.gov
> Sent: Thursday, June 9, 2011 10:45:47 AM
> Subject: Re: [cgma-dev] CGM/itaps/testgeom_occ
> Thanks for your reply.
> The test fails in "faceting_test".
> I think "faceting_test" also has to be inside "#if defined(HAVE_ACIS) &&
> !defined(FORCE_OCC)" block as you mentioned, because it is loading
> "size.sat" by itself again.
> If it is ok for you all, I will change it.
> Hong-Jun
> > From: "Jane Hu" <janejhu at gmail.com>
> > To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> > Sent: Thursday, June 9, 2011 9:47:12 AM
> > Hi, Hong-Jun:
> > testgeom is using LeverArm.brep for OCC part of testing, and it passed
> > in my machine for make check. Only with HAVE_ACIS and without
> > FORCE_OCC defined will mesh_size_test test be performed. So it is Acis
> > specific.
> > Jane
> > On Wed, Jun 8, 2011 at 1:25 PM, Hong-Jun Kim < hongjun at mcs.anl.gov >
> > wrote:
> > Hi
> > Currently, "CGM/itaps/testgeom_occ" fails for OCC geometry because
> > its' input file is "size.sat" for "faceting_test".
> > To fix this, can I ask if the test is specific to the input file,
> > "size.sat"?
> > Hong-Jun
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110609/1e452305/attachment.htm>
More information about the cgma-dev
