[cgma-dev] CGM/itaps/testgeom_occ
    Paul Wilson
    wilsonp at engr.wisc.edu
    Thu Jun  9 11:50:44 CDT 2011
Hello Hong-Jun, Jane,
I added the faceting_test method to the testgeom program and it should
have had the #ifdef blocks.  Sorry.
Paul
On 06/09/2011 08:48 PM, Jane Hu wrote:
> I don't have faceting_test in itaps directory, and make check passed
> cgm/cgm_apps/examples/facetdriver facets test too.
> Jane
> On Thu, Jun 9, 2011 at 10:52 AM, Hong-Jun Kim <hongjun at mcs.anl.gov
> <mailto:hongjun at mcs.anl.gov>> wrote:
>     By the way, I am curious why you don't fail the test.
>     Inside "faceting_test", when "size.sat" is imported to OCC
>     geometry kernel, it looks it must fail.
>     Am I wrong?
>     Hong-Jun
>     ----- Original Message -----
>     From: "Hong-Jun Kim" <hongjun at mcs.anl.gov
>     To: "Jane Hu" <janejhu at gmail.com <mailto:janejhu at gmail.com>>
>     Cc: cgma-dev at mcs.anl.gov <mailto:cgma-dev at mcs.anl.gov>
>     Sent: Thursday, June 9, 2011 10:45:47 AM
>     Subject: Re: [cgma-dev] CGM/itaps/testgeom_occ
>     Thanks for your reply.
>     The test fails in "faceting_test".
>     I think "faceting_test" also has to be inside "#if
>     defined(HAVE_ACIS) && !defined(FORCE_OCC)" block as you mentioned,
>     because it is loading "size.sat" by itself again.
>     If it is ok for you all, I will change it.
>     Hong-Jun
>     > From: "Jane Hu" <janejhu at gmail.com <mailto:janejhu at gmail.com>>
>     > To: "Hong-Jun Kim" <hongjun at mcs.anl.gov
>     > Sent: Thursday, June 9, 2011 9:47:12 AM
>     > Hi, Hong-Jun:
>     > testgeom is using LeverArm.brep for OCC part of testing, and it
>     passed
>     > in my machine for make check. Only with HAVE_ACIS and without
>     > FORCE_OCC defined will mesh_size_test test be performed. So it
>     is Acis
>     > specific.
>     > Jane
>     > On Wed, Jun 8, 2011 at 1:25 PM, Hong-Jun Kim <
>     hongjun at mcs.anl.gov <mailto:hongjun at mcs.anl.gov> >
>     > wrote:
>     > Hi
>     > Currently, "CGM/itaps/testgeom_occ" fails for OCC geometry because
>     > its' input file is "size.sat" for "faceting_test".
>     > To fix this, can I ask if the test is specific to the input file,
>     > "size.sat"?
>     > Hong-Jun
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Associate Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Chair, Energy Analysis&  Policy Program ~ http://nelson.wisc.edu/eap
Note: I will be on sabbatical for the 2010-2011 academic year.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110609/e418c4e1/attachment-0001.htm>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110609/e418c4e1/attachment-0001.bin>
More information about the cgma-dev
