[cgma-dev] CGM/itaps/testgeom_occ
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Thu Jun  9 10:52:16 CDT 2011
By the way, I am curious why you don't fail the test.
Inside "faceting_test", when "size.sat" is imported to OCC geometry kernel, it looks it must fail.
Am I wrong?
Hong-Jun
----- Original Message -----
To: "Jane Hu" <janejhu at gmail.com>
Cc: cgma-dev at mcs.anl.gov
Sent: Thursday, June 9, 2011 10:45:47 AM
Subject: Re: [cgma-dev] CGM/itaps/testgeom_occ
Thanks for your reply.
The test fails in "faceting_test".
I think "faceting_test" also has to be inside "#if defined(HAVE_ACIS) && !defined(FORCE_OCC)" block as you mentioned, because it is loading "size.sat" by itself again.
If it is ok for you all, I will change it.
Hong-Jun
> From: "Jane Hu" <janejhu at gmail.com>
> To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> Sent: Thursday, June 9, 2011 9:47:12 AM
> Hi, Hong-Jun:
> testgeom is using LeverArm.brep for OCC part of testing, and it passed
> in my machine for make check. Only with HAVE_ACIS and without
> FORCE_OCC defined will mesh_size_test test be performed. So it is Acis
> specific.
> Jane
> On Wed, Jun 8, 2011 at 1:25 PM, Hong-Jun Kim < hongjun at mcs.anl.gov >
> wrote:
> Hi
> Currently, "CGM/itaps/testgeom_occ" fails for OCC geometry because
> its' input file is "size.sat" for "faceting_test".
> To fix this, can I ask if the test is specific to the input file,
> "size.sat"?
> Hong-Jun
More information about the cgma-dev
