[cgma-dev] r4884 - in cgm/trunk: geom/OCC test
    James Porter
    jvporter at wisc.edu
    Mon Jun  6 14:08:12 CDT 2011
So I finally figured out (part of?) what's going on with the distcheck
errors. There are some missing files that never got added to this
commit: Line_1.brep and Line_2.brep.
There may be other errors of course, so adding those might not fix
everything...
On Thu, 2011-05-26 at 13:29 -0500, jiangtao_ma at yahoo.com wrote:
> Author: janehu
> Date: 2011-05-26 13:29:34 -0500 (Thu, 26 May 2011)
> New Revision: 4884
> Modified:
>    cgm/trunk/geom/OCC/OCCModifyEngine.cpp
>    cgm/trunk/geom/OCC/OCCSurface.cpp
>    cgm/trunk/test/Makefile.am
>    cgm/trunk/test/modify.cpp
> Log:
> Made changes regarding webcut using sweep curve method that is a possible bug that Yu Wenhui asked. Passed make distcheck. Testcase is in modify.cpp
> Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2011-05-26 13:49:07 UTC (rev 4883)
> +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2011-05-26 18:29:34 UTC (rev 4884)
> @@ -4442,19 +4442,17 @@
> -      else //sheet body
> -        TopoDS_Face* topoface = occ_surface->get_TopoDS_Face();
> -        TopAbs_Orientation ori = topoface->Orientation();
> -        topoface->Orientation(ori == TopAbs_FORWARD ? TopAbs_REVERSED :
> +    if(!occ_shell || occ_shell->is_sheet()) //sheet body
> +      TopoDS_Face* topoface = occ_surface->get_TopoDS_Face();
> +      TopAbs_Orientation ori = topoface->Orientation();
> +      topoface->Orientation(ori == TopAbs_FORWARD ? TopAbs_REVERSED :
>                                                      TopAbs_FORWARD);
> -        occ_surface->set_TopoDS_Face(*topoface);
> -        surface_list.append(occ_surface);
> +      occ_surface->set_TopoDS_Face(*topoface);
> +      surface_list.append(occ_surface);
>        PRINT_INFO( "Modified volume\n" );
> -    else
> -      PRINT_WARNING( "Volume was not modified\n" );
>    face_list = surface_list;
>    return CUBIT_SUCCESS;
> @@ -4639,22 +4637,12 @@
>  CubitStatus OCCModifyEngine::get_sweepable_toposhape(OCCCurve*& curve,
>                                                TopoDS_Shape& toposhape)const
> -  DLIList<OCCLoop*> loops;
> -  loops =  curve->loops();
> -  if( loops.size()) //not a free curve
> -    //copy the curve
> -    Curve* c_curve = make_Curve(curve);
> -    if(c_curve)
> -     curve = CAST_TO(c_curve, OCCCurve);
> -    else
> -      PRINT_ERROR("Can't copy the curve for sweep.\n");
> -      return CUBIT_FAILURE;
>    TopoDS_Edge *edge = curve->get_TopoDS_Edge( );
More information about the cgma-dev
