[cgma-dev] buildbot failure in cgm-distcheck: failed compile
    Jane Hu
    janejhu at gmail.com
    Fri Jun  3 09:35:53 CDT 2011
FYI:
Make distcheck run perfectly fine on my local machine.
Jane
On Fri, Jun 3, 2011 at 12:54 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-distcheck<http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck>build
> #479 <http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck/builds/479> *
> Results:*failed compile *Buildslave:*gnep *Revision:*None *Reason:*The
> Nightly scheduler named 'nightly' triggered this build Log Excerpt
> (CDPATH="${ZSH_VERSION+.}:" && cd ../.. && /bin/sh /disks/itaps-buildslave/cgm-distcheck/build/missing --run autoheader)
> rm -f stamp-h2
> touch CGMmpi_config.h.in
> cd ../.. && /bin/sh ./config.status geom/parallel/CGMmpi_config.h
> config.status: creating geom/parallel/CGMmpi_config.h
> config.status: geom/parallel/CGMmpi_config.h is unchanged
>  ... (cd OCC && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/geom/OCC \
>      am__remove_distdir=: am__skip_length_check=: am__skip_mode_fix=: distdir)
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/OCC'
>  ... (cd init && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/init \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/init'
>  ... (cd itaps && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/itaps \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/itaps'
> (CDPATH="${ZSH_VERSION+.}:" && cd .. && /bin/sh /disks/itaps-buildslave/cgm-distcheck/build/missing --run autoheader)
> rm -f stamp-h4
> touch iBase_FCDefs.h.in
> cd .. && /bin/sh ./config.status itaps/iBase_FCDefs.h
> config.status: creating itaps/iBase_FCDefs.h
> config.status: itaps/iBase_FCDefs.h is unchanged
> echo '#include "iGeom_FCDefs.h"' > iGeom_protos.h && \
> 	echo '#ifdef IGEOM_FC_FUNC_' >> iGeom_protos.h && \
> 	echo >> iGeom_protos.h && \
> 	for func in `/bin/sed -n 's/^[[:space:]]*void[[:space:]][[:space:]]*iGeom_\([a-z][_a-zA-Z0-9]*\)[[:space:]]*(.*$/iGeom_\1/p' iGeom.h`; do \
> 	  lower=`echo $func | tr '[:upper:]' '[:lower:]'`; \
>           upper=`echo $func | tr '[:lower:]' '[:upper:]'`; \
> 	  echo "#define $func IGEOM_FC_FUNC_( $lower, $upper )" >> iGeom_protos.h; \
>         done && \
> 	echo "#endif" >> iGeom_protos.h
>  (cd SIDL && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/itaps/SIDL \
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/itaps/SIDL'
> test -d ../../cgma-10.2.3/itaps/SIDL || /bin/mkdir -p ../../cgma-10.2.3/itaps/SIDL || exit 1
> test -d ../../cgma-10.2.3/itaps/SIDL/gserver || /bin/mkdir -p ../../cgma-10.2.3/itaps/SIDL/gserver || exit 1
> /bin/sh: line 1: @ECHO@: command not found
>  ... (cd test && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/test \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/test'
> make[2]: *** No rule to make target `Line_1.brep', needed by `distdir'.  Stop.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110603/f77eed9a/attachment.htm>
More information about the cgma-dev
