[cgma-dev] buildbot failure in cgm-distcheck: failed compile
    Jane Hu
    janejhu at gmail.com
    Fri May 27 09:22:05 CDT 2011
It passed make distcheck on my machine. I am not sure what is the matter in
gnep. Can someone take a look at this issue? Thank you!
Jane
On Fri, May 27, 2011 at 12:58 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-distcheck<http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck>build
> #477 <http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck/builds/477> *
> Results:*failed compile *Buildslave:*gnep *Revision:*None *Reason:*The
> Nightly scheduler named 'nightly' triggered this build Log Excerpt
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/facet'
>  ... (cd virtual && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/geom/virtual \
>      am__remove_distdir=: am__skip_length_check=: am__skip_mode_fix=: distdir)
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/virtual'
>  ... (cd ACIS && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/geom/ACIS \
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/ACIS'
>  ... (cd parallel && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/geom/parallel \
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/parallel'
> (CDPATH="${ZSH_VERSION+.}:" && cd ../.. && /bin/sh /disks/itaps-buildslave/cgm-distcheck/build/missing --run autoheader)
> rm -f stamp-h2
> touch CGMmpi_config.h.in
> cd ../.. && /bin/sh ./config.status geom/parallel/CGMmpi_config.h
> config.status: creating geom/parallel/CGMmpi_config.h
> config.status: geom/parallel/CGMmpi_config.h is unchanged
>  ... (cd OCC && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/geom/OCC \
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/geom/OCC'
>  ... (cd init && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/init \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/init'
>  ... (cd itaps && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/itaps \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/itaps'
> (CDPATH="${ZSH_VERSION+.}:" && cd .. && /bin/sh /disks/itaps-buildslave/cgm-distcheck/build/missing --run autoheader)
> rm -f stamp-h4
> touch iBase_FCDefs.h.in
> cd .. && /bin/sh ./config.status itaps/iBase_FCDefs.h
> config.status: creating itaps/iBase_FCDefs.h
> config.status: itaps/iBase_FCDefs.h is unchanged
>  (cd SIDL && make  top_distdir=../../cgma-10.2.3 distdir=../../cgma-10.2.3/itaps/SIDL \
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/itaps/SIDL'
> test -d ../../cgma-10.2.3/itaps/SIDL || /bin/mkdir -p ../../cgma-10.2.3/itaps/SIDL || exit 1
> test -d ../../cgma-10.2.3/itaps/SIDL/gserver || /bin/mkdir -p ../../cgma-10.2.3/itaps/SIDL/gserver || exit 1
> /bin/sh: line 1: @ECHO@: command not found
>  ... (cd test && make  top_distdir=../cgma-10.2.3 distdir=../cgma-10.2.3/test \
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-distcheck/build/test'
> make[2]: *** No rule to make target `Line_1.brep', needed by `distdir'.  Stop.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110527/8654b665/attachment.htm>
More information about the cgma-dev
