[cgma-dev] r4863 - cgm/trunk/test
jiangtao_ma at yahoo.com
Tue May 24 10:44:38 CDT 2011
Author: janehu
Date: 2011-05-24 10:44:38 -0500 (Tue, 24 May 2011)
New Revision: 4863
Added:
cgm/trunk/test/webcut.brep
Modified:
cgm/trunk/test/Makefile.am
cgm/trunk/test/modify.cpp
Log:
Testcase to support the webcut bug fix. Passed make distcheck.
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2011-05-24 15:15:30 UTC (rev 4862)
+++ cgm/trunk/test/Makefile.am 2011-05-24 15:44:38 UTC (rev 4863)
@@ -82,6 +82,7 @@
ex3.iges \
Cylinder_1.brep \
Cylinder_2.brep \
+ webcut.brep \
stitch.name_occ
# Files that are created by tests, and that therefore
@@ -124,6 +125,7 @@
bug.brep \
subtract.occ \
glue.occ \
+ after_webcut.brep \
mmgr.log
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2011-05-24 15:15:30 UTC (rev 4862)
+++ cgm/trunk/test/modify.cpp 2011-05-24 15:44:38 UTC (rev 4863)
@@ -1279,5 +1279,36 @@
assert (CAST_TO(ref_entity_list.get(), Body)->num_ref_faces() == 7);
assert (CAST_TO(ref_entity_list.get_and_step(), Body)->num_ref_edges() == 11);
assert (CAST_TO(ref_entity_list.get(), Body)->num_ref_volumes() == 1);
+ bodies.clean_out();
+ gti->bodies(bodies);
+ //delete all entities
+ gti->delete_Body(bodies);
+ free_entities.clean_out();
+ gti->get_free_ref_entities(free_entities);
+ for(int i = 0; i < free_entities.size(); i++)
+ gti->delete_RefEntity(free_entities.get_and_step());
+ // Read in the geometry from files specified on the command line
+ argv = "webcut.brep";
+ read_geometry(1, &argv, false);
+ DLIList<Body*> old_bodies, junk;
+ new_bodies.clean_out();
+ gti->bodies(old_bodies);
+ CubitVector center_l(0, 0, 0);
+ CubitVector axis(0.,0.,1.);
+ double radius = 0.5;
+ rsl= gmti->webcut_with_cylinder(old_bodies,radius,axis, center_l,new_bodies,junk);
More information about the cgma-dev
