[cgma-dev] r4801 - cgm/trunk
    jiangtao_ma at yahoo.com
    Thu May  5 12:22:45 CDT 2011
Author: janehu
Date: 2011-05-05 12:22:43 -0500 (Thu, 05 May 2011)
New Revision: 4801
Modified:
   cgm/trunk/README.OpenCascade
Log:
Updated with build and capability info.
Modified: cgm/trunk/README.OpenCascade
--- cgm/trunk/README.OpenCascade	2011-05-05 16:59:52 UTC (rev 4800)
+++ cgm/trunk/README.OpenCascade	2011-05-05 17:22:43 UTC (rev 4801)
@@ -1,5 +1,19 @@
-                    GM on OCC6.3 capabilities
+		    Build CGM on Opencascade 6.5
+•	Please download Opencascade6.5 source package at
+	http://www.opencascade.org/getocc/download/loadocc/
+•	Then follow the link instruction to build OCC libraries.
+	http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
+• 	Download CGM trunk files, then under trunk do
+	•	autoreconf -fi
+        •       ./configure --with-occ=(your occ dir, parent dir of ros) --prefix=Your install dir.
+        •	make or make install
+	•  	make check to see some examples of the testcases running.
+                    CGM on OCC6.5 capabilities
 1.	Query
 •	Import/Export OpenCascade  b-rep files, create CGM geometry/topology entities.
@@ -9,6 +23,7 @@
 •	Delete entities build on OCC engine.
 •	Translate/Rotate/Scale/Reflect objects.
+        Added scale with 3 different scale factors in 3 axes.
 •	Detect body overlap
@@ -20,20 +35,35 @@
 •	Get bounding boxes for entities.
+•	Get facets info for surfaces and curves.
 2.	Modify
 •	Create CGM geometry entities using OpenCascade engine. Top-Down method: directly create points, curves, surfaces or solid primitives.
 •	Create CGM geometry entities using OpenCascade engine, Bottom-Up method: curve generates by points, surface generates by curves and solid generates by surfaces.
+•	Copy body.
 •	Boolean operations: subtract, unite, intersect.
 •	Project curve on surface
More information about the cgma-dev
