[cgma-dev] r4798 - cgm/trunk/itaps
jiangtao_ma at yahoo.com
Tue May 3 12:44:23 CDT 2011
Author: janehu
Date: 2011-05-03 12:44:21 -0500 (Tue, 03 May 2011)
New Revision: 4798
Modified:
cgm/trunk/itaps/iGeom.h
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Added function iGeom_getFacets in iGeom interface. Removed previous two functions for getting graphics info on ref_entities. Passed the test in this dir.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h 2011-05-03 17:17:50 UTC (rev 4797)
+++ cgm/trunk/itaps/iGeom.h 2011-05-03 17:44:21 UTC (rev 4798)
@@ -3921,6 +3921,13 @@
iBase_EntitySetHandle* result_entity_set,
int *err );
+ void iGeom_getFacets(iGeom_Instance instance,
+ iBase_EntityHandle entity,
+ double dist_tolerance,
+ double **points, int *points_allocated, int *points_size,
+ int **facets, int *facets_allocated, int *facets_size,
+ int *err);
#ifdef __cplusplus
} // extern "C"
#endif
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2011-05-03 17:17:50 UTC (rev 4797)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2011-05-03 17:44:21 UTC (rev 4798)
@@ -7063,65 +7063,69 @@
RETURN(iBase_SUCCESS);
-static
-CubitStatus iGeom_get_graphics(RefFace* face,
- DLIList<CubitVector*>& point_list,
- DLIList<int>& facet_list,
- unsigned short normal_tolerance ,
- double distance_tolerance ,
- double longest_edge )
+void iGeom_getFacets(iGeom_Instance instance,
+ int *err)
- GMem facets;
- CubitStatus resl = face->get_graphics(facets, normal_tolerance,
- distance_tolerance, longest_edge);
- if(resl == CUBIT_FAILURE)
- return resl;
+ GMem gMem;
+ CubitStatus resl = CUBIT_SUCCESS;
+ RefFace *ref_face = dynamic_cast<RefFace*>(ENTITY_HANDLE(entity));
+ if(ref_face)
+ resl = ref_face->get_graphics(gMem, 15, dist_tolerance);
More information about the cgma-dev
