[cgma-dev] r4793 - cgm/trunk/geom/OCC
hongjun at mcs.anl.gov hongjun at mcs.anl.gov
Tue May 3 10:05:04 CDT 2011
Author: hongjun
Date: 2011-05-03 10:05:04 -0500 (Tue, 03 May 2011)
New Revision: 4793
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
o "OCCQueryEngine::Write" using buffer is reverted to use "b_write_buffer" flag
o Passes make check
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-05-03 01:16:35 UTC (rev 4792)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-05-03 15:05:04 UTC (rev 4793)
@@ -1364,16 +1364,17 @@
   long size=infile.tellg();
   infile.seekg(0);
-  if(n_buffer_size < size)
-    PRINT_ERROR("Buffer size is not enough, increase buffer size.\n");
-    infile.close();
-    remove(file_name);
-    return CUBIT_FAILURE;
+  if (b_write_buffer) {
+    if(n_buffer_size < size) {
+      PRINT_ERROR("Buffer size is not enough, increase buffer size.\n");
+      infile.close();
+      remove(file_name);
+      return CUBIT_FAILURE;
+    infile.read(pBuffer,size);
   else n_buffer_size = size;
-  infile.read(pBuffer,size);
   infile.close();
   remove(file_name);
   return CUBIT_TRUE;
More information about the cgma-dev mailing list
