[cgma-dev] r4790 - cgm/trunk/itaps
Tim Tautges
tautges at mcs.anl.gov
Mon May 2 14:08:18 CDT 2011
Maybe I need to be a bit more specific in my request that Jane implement functions in iGeom to get facet information.
The function signature I'm looking for is:
iGeom_getFacets(iGeom_EntityHandle entity,
double dist_tolerance,
double **points, int *points_alloc, int *points_size,
int **facets, int *facets_alloc, int *facets_size)
This should be a function that appears in iGeom.h, and is implemented in iGeom_CGMA.cc by calling functions in CGM. I
know the CGM RefFace function has more options, but I don't think we should expose those options in iGeom (or, at least,
I don't know whether they're common enough across modeling engines, maybe you can investigate that too based on OCC).
- tim
On 05/02/2011 01:23 PM, Jason Kraftcheck wrote:
> Should we drop the general facet concept from Cubit and instead assume
> triangles?
> What use are these functions? They just copy the data from the Cubit GMem
> object to DLILists. Both are CGM-specific data structures.
> Why return a DLIList of pointers to dynamically allocated CubitVector
> instances? Why not just a std::vector of CubitVectors? Or an std::vector
> of floats if the extra precision isn't required.
> This loop (present in both functions) looks wrong:
> for(int i = 0; i< facets.facet_list_size(); i++)
> facet_list.append(list[i]);
> i++;
> - jason
> On 05/02/2011 01:08 PM, jiangtao_ma at yahoo.com wrote:
>> Author: janehu
>> Date: 2011-05-02 13:08:11 -0500 (Mon, 02 May 2011)
>> New Revision: 4790
>> Modified:
>> cgm/trunk/itaps/iGeom_CGMA.cc
>> Log:
>> Added iGeom function to pass out facet info for RefFaces and RefEdges.
>> Modified: cgm/trunk/itaps/iGeom_CGMA.cc
>> --- cgm/trunk/itaps/iGeom_CGMA.cc 2011-05-02 16:48:16 UTC (rev 4789)
>> +++ cgm/trunk/itaps/iGeom_CGMA.cc 2011-05-02 18:08:11 UTC (rev 4790)
>> @@ -22,7 +22,7 @@
>> #include "iGeom.h"
>> #include "InitCGMA.hpp"
>> +#include "GMem.hpp"
>> #include<iostream>
>> #include<math.h>
>> #include "GeometryQueryTool.hpp"
>> @@ -278,7 +278,20 @@
>> DLIList<RefEntity*>& target_list,
>> int* err );
>> +static
>> +CubitStatus iGeom_get_graphics(RefFace* face,
>> + DLIList<CubitVector*>& point_list,
>> + DLIList<int>& facet_list,
>> + unsigned short normal_tolerance = 15,
>> + double distance_tolerance = 0,
>> + double longest_edge = 0) ;
>> +static
>> +CubitStatus iGeom_get_graphics(RefEdge* edge,
>> + double tolerance = 0.0 ) ;
>> static CubitStatus init_cgm( const std::string& engine )
>> CubitStatus status;
>> @@ -7049,3 +7062,66 @@
>> RETURN(iBase_SUCCESS);
>> +static
>> + unsigned short normal_tolerance ,
>> + double distance_tolerance ,
>> + double longest_edge )
>> + GMem facets;
>> + CubitStatus resl = face->get_graphics(facets, normal_tolerance,
>> + distance_tolerance, longest_edge);
>> + if(resl == CUBIT_FAILURE)
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
