[cgma-dev] r4786 - cgm/trunk/geom/OCC
    jiangtao_ma at yahoo.com
    Fri Apr 29 11:20:04 CDT 2011
Author: janehu
Date: 2011-04-29 11:20:04 -0500 (Fri, 29 Apr 2011)
New Revision: 4786
Modified:
   cgm/trunk/geom/OCC/occ_patches
Log:
give the pathes to the patches. Added one from r4440 back.
Modified: cgm/trunk/geom/OCC/occ_patches
--- cgm/trunk/geom/OCC/occ_patches	2011-04-28 23:15:21 UTC (rev 4785)
+++ cgm/trunk/geom/OCC/occ_patches	2011-04-29 16:20:04 UTC (rev 4786)
@@ -1,38 +1,5 @@
---- BRepClass_FaceClassifier.cxx_old	2011-04-28 10:16:13.000000000 -0500
-+++ BRepClass_FaceClassifier.cxx	2011-04-28 10:16:51.000000000 -0500
-@@ -55,6 +55,7 @@
-   Extrema_ExtPS myExtrem;
-   //-- myExtrem.Initialize(HS, U1, U2, V1, V2, Tol, Tol);
-   myExtrem.Initialize(Surf, U1, U2, V1, V2, Tol, Tol);
-+  myExtrem.Perform(P);
-   //-- On cherche le point le plus proche , PUIS
-   //-- On le classifie.
---- Extrema_ExtPS.cxx_old	2011-04-28 10:13:52.000000000 -0500
-+++ Extrema_ExtPS.cxx	2011-04-28 10:15:46.000000000 -0500
-@@ -88,10 +88,18 @@
-   Standard_Real U, V;
-   PS.Parameter(U, V);
-   if (myS->IsUPeriodic()) {
--    U = ElCLib::InPeriod(U, myuinf, myuinf+myS->UPeriod());
-+    Standard_Real Uupper = myuinf+myS->UPeriod();
-+    if(U>(myuinf-mytolu) && U < myuinf) U = myuinf;
-+    else if(U < (Uupper+mytolu) && U > Uupper) U = Uupper;
-+    else
-+      U = ElCLib::InPeriod(U, myuinf, myuinf+myS->UPeriod());
-   if (myS->IsVPeriodic()) {
--    V = ElCLib::InPeriod(V, myvinf, myvinf+myS->VPeriod());
-+    Standard_Real Vupper = myvinf+myS->VPeriod();
-+    if(V>(myvinf-mytolv) && V < myvinf) V = myvinf;
-+    else if(V < (Vupper+mytolv) && V > Vupper) V = Vupper;
-+    else
-+      V = ElCLib::InPeriod(V, myvinf, myvinf+myS->VPeriod());
-   if ((myuinf-U) <= mytolu && (U-myusup) <= mytolu &&
-       (myvinf-V) <= mytolv && (V-myvsup) <= mytolv) {
---- Extrema_ExtPElS.cxx_old	2011-04-28 11:48:39.000000000 -0500
-+++ Extrema_ExtPElS.cxx	2011-04-28 10:13:38.000000000 -0500
+--- OpenCASCADE6.3.0/ros/src/Extrema/Extrema_ExtPElS.cxx	2011-04-28 11:48:39.000000000 -0500
++++ Extrema_ExtPElS.cxx	2011-04-29 10:16:43.000000000 -0500
 @@ -56,6 +56,7 @@
    gp_Vec myZ = Pos.XDirection()^Pos.YDirection();
    Standard_Real U1 = gp_Vec(Pos.XDirection()).AngleWithRef(OPp,myZ); //-PI<U1<PI
@@ -76,3 +43,52 @@
    if (V1 < 0.) { V1 += 2. * PI; }
    if (V2 < 0.) { V2 += 2. * PI; }
+--- OpenCASCADE6.3.0/ros/src/Extrema/Extrema_ExtPS.cxx	2011-04-28 10:13:52.000000000 -0500
++++ Extrema_ExtPS.cxx	2011-04-29 10:16:43.000000000 -0500
More information about the cgma-dev
