[cgma-dev] r4782 - cgm/trunk/geom/OCC
Iulian Grindeanu
iulian at mcs.anl.gov
Thu Apr 28 16:54:32 CDT 2011
Hello,
What is the command to apply the patch?
Where do we have to be in the source code to apply it?
I did not manage to build occ in my own space, so I am reluctant to apply it in the fathom build.
I never applied a patch :(
read_cgm_test fails in moab, but meshkit tests work fine (so everything built parallel, occ, static)
So in my occ based build, test_occ fails in cgm, read_cgm_test fails on moab, Lasso test fails, but all meshkit tests pass
Lasso tests fails on cubit 12 based build too, that is the only error in that build.
Iulian
----- Original Message -----
> occ_patches is a patch file you can apply to the OCC 6.3 source
> (there's a similar occ_patches_6.5 for OCC 6.5). From
> what Jane has said, after applying that all the tests should run.
> - tim
> On 04/28/2011 01:54 PM, Iulian Grindeanu wrote:
> > Hello,
> > I have a question about cgm build configured with occ. I have an
> > error in test/test_occ (it does not pass)
> > With the debugger, I see that the error is happening in
> > Extrema_ExtPS.
> > backtrace
> > #0 OCCSurface::u_v_from_position (this=0xcbe880, location=...,
> > u=@0x7fffffffdec8, v=@0x7fffffffdec0,
> > closest_location=0x7fffffffdcf0) at OCCSurface.cpp:428
> > #1 0x00000000005a8847 in RefFace::u_v_from_position (this=0xcd7d90,
> > location=..., u=@0x7fffffffdec8, v=@0x7fffffffdec0,
> > closest_location=0x7fffffffdcf0) at RefFace.cpp:908
> > #2 0x0000000000420643 in main (argc=1, argv=0x7fffffffe018) at
> > test_occ.cpp:98
> > Then I see that some patches are required.
> > Do we have to modify the occ source code? What is occ_patches?
> > How do we do that?
> > We are using an occ build 6.3.0, which was last build on Sep 23,
> > 2009
> > The build is here, for mcs network
> > /homes/fathom/3rdparty/occ/OpenCASCADE6.3.0/
> > (installed library is at
> > /homes/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc)
> > What am I missing?
> > Thanks,
> > Iulian
> >> Author: janehu
> >> Date: 2011-04-28 11:53:43 -0500 (Thu, 28 Apr 2011)
> >> New Revision: 4782
> >> Modified:
> >> cgm/trunk/geom/OCC/occ_patches
> >> Log:
> >> Correct previous patches for OCC6.3 build, which caused testcase
> >> check
> >> failure on gnep.
> >> Modified: cgm/trunk/geom/OCC/occ_patches
> >> --- cgm/trunk/geom/OCC/occ_patches 2011-04-28 00:36:18 UTC (rev
> >> 4781)
> >> +++ cgm/trunk/geom/OCC/occ_patches 2011-04-28 16:53:43 UTC (rev
> >> 4782)
> >> @@ -1,118 +1,78 @@
> >> ---- ros/src/Extrema/Extrema_ExtPElS.cxx 2011-03-29
> >> 11:35:08.000000000
> >> -0500
> >> /mnt/disk2b/jhu/tempdir/OpenCASCADE6.3.0/ros/src/Extrema/Extrema_ExtPElS.cxx
> >> 2002-04-23 11:10:21.000000000 -0500
> >> -@@ -56,7 +56,6 @@
> >> +--- BRepClass_FaceClassifier.cxx_old 2011-04-28 10:16:13.000000000
> >> -0500
> >> ++++ BRepClass_FaceClassifier.cxx 2011-04-28 10:16:51.000000000
> >> -0500
> >> +@@ -55,6 +55,7 @@
> >> + Extrema_ExtPS myExtrem;
> >> + //-- myExtrem.Initialize(HS, U1, U2, V1, V2, Tol, Tol);
> >> + myExtrem.Initialize(Surf, U1, U2, V1, V2, Tol, Tol);
> >> ++ myExtrem.Perform(P);
> >> + //-- On cherche le point le plus proche , PUIS
> >> + //-- On le classifie.
> >> +--- Extrema_ExtPS.cxx_old 2011-04-28 10:13:52.000000000 -0500
> >> ++++ Extrema_ExtPS.cxx 2011-04-28 10:15:46.000000000 -0500
> >> +@@ -88,10 +88,18 @@
> >> + Standard_Real U, V;
> >> + PS.Parameter(U, V);
> >> + if (myS->IsUPeriodic()) {
> >> +- U = ElCLib::InPeriod(U, myuinf, myuinf+myS->UPeriod());
> >> ++ Standard_Real Uupper = myuinf+myS->UPeriod();
> >> ++ if(U>(myuinf-mytolu)&& U< myuinf) U = myuinf;
> >> ++ else if(U< (Uupper+mytolu)&& U> Uupper) U = Uupper;
> >> ++ else
> >> ++ U = ElCLib::InPeriod(U, myuinf, myuinf+myS->UPeriod());
> >> + if (myS->IsVPeriodic()) {
> >> +- V = ElCLib::InPeriod(V, myvinf, myvinf+myS->VPeriod());
> >> ++ Standard_Real Vupper = myvinf+myS->VPeriod();
> >> ++ if(V>(myvinf-mytolv)&& V< myvinf) V = myvinf;
> >> ++ else if(V< (Vupper+mytolv)&& V> Vupper) V = Vupper;
> >> ++ else
> >> ++ V = ElCLib::InPeriod(V, myvinf, myvinf+myS->VPeriod());
> >> + if ((myuinf-U)<= mytolu&& (U-myusup)<= mytolu&&
> >> + (myvinf-V)<= mytolv&& (V-myvsup)<= mytolv) {
> >> +--- Extrema_ExtPElS.cxx_old 2011-04-28 11:48:39.000000000 -0500
> >> ++++ Extrema_ExtPElS.cxx 2011-04-28 10:13:38.000000000 -0500
> >> +@@ -56,6 +56,7 @@
> >> gp_Vec myZ = Pos.XDirection()^Pos.YDirection();
> >> Standard_Real U1 = gp_Vec(Pos.XDirection()).AngleWithRef(OPp,myZ);
> >> //-PI<U1<PI
> >> Standard_Real U2 = U1 + PI;
> >> -- if(U1> -Tol&& U1< 0.) {U1 = 0.;}
> >> ++ if(U1> -Tol&& U1< 0.) {U1 = 0.;}
> >> if (U1< 0.) { U1 += 2. * PI; }
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
