[cgma-dev] r4755 - in cgm/branches/merge-cubit12: geom/ACIS_SRC	geom/OCC geom/testing test
    jiangtao_ma at yahoo.com
    Wed Apr 20 12:39:28 CDT 2011
Author: janehu
Date: 2011-04-20 12:39:28 -0500 (Wed, 20 Apr 2011)
New Revision: 4755
Modified:
   cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp
   cgm/branches/merge-cubit12/geom/OCC/OCCQueryEngine.cpp
   cgm/branches/merge-cubit12/geom/testing/main.cpp
   cgm/branches/merge-cubit12/test/modify.cpp
Log:
Check the TopoDS_Edge to see if its two vertices are identical for sliver edges, and not generate curve on such edge in CGM, there's a corespoinding change in testcase cgm/test/modify.
Fixed the a bug in creating oriented brick, testcase is in cgm/geom/testing/CreateGeometry.
Removed unnecessary error count manipulation in geom/testing/main.cpp
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp	2011-04-20 17:37:18 UTC (rev 4754)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp	2011-04-20 17:39:28 UTC (rev 4755)
@@ -3840,7 +3840,7 @@
 //                 and size.
 // Special Notes : Extension is equivalent to 1/2 width, depth, height.
+//                 Center is the coordinates in global system.
 // Creator       : Steve Storm
 // Creation Date : 10/09/00
Modified: cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp	2011-04-20 17:37:18 UTC (rev 4754)
+++ cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp	2011-04-20 17:39:28 UTC (rev 4755)
@@ -1457,6 +1457,7 @@
 // Member Type: PUBLIC
 // Description: create an OCC brick given center axes and extension
 //              extension is equvlent to (wid/2, dep/2, hi/2)
+//              center should be given the coordinates in global system
 // Author     : Jane Hu
 // Date       : 03/08
@@ -1464,8 +1465,7 @@
                                 const CubitVector axes[3],
                                 const CubitVector &extension) const
-  CubitVector left_corner =  center - extension;
-  gp_Pnt left_point(left_corner.x(), left_corner.y(), left_corner.z());
+  gp_Pnt left_point(0,0,0);
   gp_Dir main_dir(axes[2].x(), axes[2].y(), axes[2].z());
   gp_Dir x_dir(axes[0].x(), axes[0].y(), axes[0].z());
   gp_Ax2 Axis(left_point, main_dir, x_dir);
@@ -1477,7 +1477,17 @@
   if (lump == NULL)
     return (BodySM*)NULL;
-  return CAST_TO(lump, OCCLump)->get_body();
+  BodySM* body = CAST_TO(lump, OCCLump)->get_body();
+  if(body)
+    CubitVector center_point;
+    double volume;
+    OCCBody* occ_body = CAST_TO(body,OCCBody);
+    occ_body->mass_properties(center_point, volume);
+    CubitVector move_vec = center - center_point;
+    occ_body->move(move_vec.x(), move_vec.y(), move_vec.z());
+    return body;
More information about the cgma-dev
