[cgma-dev] buildbot failure in cgm-occ: failed test
    Jane Hu
    janejhu at gmail.com
    Tue Apr 19 09:53:52 CDT 2011
Hello,
Is this build with OCC6.5 and merge-cubit12 branch? I just checked out the
whole merge-cubit12 branch and built with OCC6.5, and it passed all 12
testcases.
Jane
On Tue, Apr 19, 2011 at 12:51 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-occ<http://gnep.mcs.anl.gov:8010/builders/cgm-occ>build
> #452 <http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/452> *Results:*failed
> test *Buildslave:*gnep *Revision:*None *Reason:*The Nightly scheduler
> named 'nightly' triggered this build Log Excerpt
> makept.cpp:423: warning: unused variable ‘new_face2’
> makept.cpp:519: warning: unused variable ‘num_loops’
> makept.cpp:612: warning: unused variable ‘new_edge’
> mv -f .deps/makept.Tpo .deps/makept.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o makept makept.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o makept makept.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.
>  so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE
>  6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o r_w.cpp
> mv -f .deps/r_w.Tpo .deps/r_w.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o r_w r_w.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o r_w r_w.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.so /ho
>  mes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o test_occ.cpp
> mv -f .deps/test_occ.Tpo .deps/test_occ.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o test_occ test_occ.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o test_occ test_occ.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHeal
>  ing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCAS
>  CADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT operation.o -MD -MP -MF .deps/operation.Tpo -c -o operation.o operation.cpp
> mv -f .deps/operation.Tpo .deps/operation.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o operation operation.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o operation operation.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHe
>  aling.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenC
>  ASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H '-DTEST_ENGINE="OCC"'   -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick_occ-brick.o -MD -MP -MF .deps/brick_occ-brick.Tpo -c -o brick_occ-brick.o `test -f 'brick.cpp' || echo './'`brick.cpp
> /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int main(int, char**)’:
> /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array subscript is above array bounds
> mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o brick_occ brick_occ-brick.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_occ brick_occ-brick.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/lib
>  TKShHealing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC
>  /OpenCASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DTEST_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT merge_occ-merge_test.o -MD -MP -MF .deps/merge_occ-merge_test.Tpo -c -o merge_occ-merge_test.o `test -f 'merge_test.cpp' || echo './'`merge_test.cpp
> mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o merge_occ merge_occ-merge_test.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o merge_occ merge_occ-merge_test.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/li
>  b/libTKShHealing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdpart
>  y/OCC/OpenCASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
>  ...make  check-TESTS
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
>  [0;32mPASS [m: init
>  [0;32mPASS [m: sheet
>  [0;32mPASS [m: brick_facet
>  [0;32mPASS [m: merge_facet
> /bin/sh: line 1: 20802 Aborted                 "$tst" > modify.log-t 2>&1
>  [0;31mFAIL [m: modify
>  [0;32mPASS [m: subtract
>  [0;32mPASS [m: makept
>  [0;32mPASS [m: r_w
>  [0;32mPASS [m: test_occ
>  [0;32mPASS [m: operation
>  [0;32mPASS [m: brick_occ
>  [0;32mPASS [m: merge_occ
>  [0;31m=======================
> 1 of 12 tests failed
> See test/test-suite.log
>  [mmake[4]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110419/6fb0edfe/attachment-0001.htm>
More information about the cgma-dev
