[cgma-dev] r4747 - cgm/branches/merge-cubit12/itaps
    jiangtao_ma at yahoo.com
    Mon Apr 18 11:22:25 CDT 2011
Author: janehu
Date: 2011-04-18 11:22:25 -0500 (Mon, 18 Apr 2011)
New Revision: 4747
Modified:
   cgm/branches/merge-cubit12/itaps/testgeom.cc
Log:
Comment out testcase failure code for Save EntSet per Tim's requirement. Now itaps/testgeom passes under OCC6.3, OCC6.5, acis17.
Modified: cgm/branches/merge-cubit12/itaps/testgeom.cc
--- cgm/branches/merge-cubit12/itaps/testgeom.cc	2011-04-18 15:30:56 UTC (rev 4746)
+++ cgm/branches/merge-cubit12/itaps/testgeom.cc	2011-04-18 16:22:25 UTC (rev 4747)
@@ -1302,6 +1302,7 @@
   err = get_entities( geom, iBase_REGION, vols,   id, &vol_ids   ); CHECK("");
     // expect interval count to be the same as ID for every curve
+/* testgeom didn't pass with the following call, uncomment it when fixed.
   std::vector<int> intervals(curves.size());
   int *int_ptr = &intervals[0];
   junk1 = junk2 = curves.size();
@@ -1347,7 +1348,7 @@
     // expect "SOFT" firmness on all surfaces
   err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" );
   CHECK("Invalid surface firmness");
     // expect no firmnes on other entities
   err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
   CHECK("Got firmness for vertex.");
More information about the cgma-dev
