[cgma-dev] r4731 - cgm/branches/merge-cubit12/geom/testing
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Apr 12 12:00:08 CDT 2011
On 04/12/2011 11:22 AM, jiangtao_ma at yahoo.com wrote:
> Author: janehu Date: 2011-04-12 11:22:51 -0500 (Tue, 12 Apr 2011) New
> Revision: 4731
> Modified: cgm/branches/merge-cubit12/geom/testing/CreateGeometry.cpp
> Log: Modified the axes for generating rotated box. The original axes are
> not perpendicular to each other, ACIS and OCC use different two pairs of
> axesa(x,y) and (x,z) to create local coordiante system.
We need the CGM API to behave the same for OCC and ACIS.  Please fix your
code so that it behaves the same as the ACIS code rather than changing the
test such that it only works with OCC.
- jason
More information about the cgma-dev
