[cgma-dev] [Meshkit-dev] installing Meshkit
    Paul Wilson
    wilsonp at engr.wisc.edu
    Thu Apr  7 18:23:46 CDT 2011
Hi Steve,
I'm curious to know what you think is different about the Mac versions
that would cause this kind of issue?  (Short of actually debugging the
problem - more of an assessment of where the problem might be.)
Paul
On 04/07/2011 10:48 AM, Steve Jackson wrote:
> On Apr 7, 2011, at 10:24 , Tim Tautges wrote:
>> On 04/07/2011 09:21 AM, Avery Bingham wrote:
>>> I have a few questions on installing MeshKit.
>>> First, has it been installed on a Mac? Second I am having some difficulties getting CGM installed.  I use Cubit, but
>>> I have a prebuilt version and I cant get the configure file to use the cubit libraries from my installed version.
>>> Unfortunately I don't have ACIS or access to the cubit source code.   This seems to be a road block to installing
>>> MeshKit.  Do you have a suggested workaround?
>> This should be installable on a mac, though I'm not sure if anybody has actually tested that.
> That's a good question.  I spent some time trying to build CGM (merge-cubit12 branch) against Cubit 12.2 on Mac OS 10.6, and I got nowhere: I cannot find a way to successfully link against the libcubiti19 file that's inside in the Cubit application.  (I can convince the linker to link against this file, but I cannot reference any symbols without producing undefined symbol errors.)   This prevents CGM from passing its configure step.
> I haven't time to work on this further, but if anyone with a Mac wants to look at this more closely, they can contact me for details about what I've tried so far.
> (Would it be practical to set up MeskKit to build without CGM, or with a CGM that doesn't have a geometry backend installed?  It seems like the greatest burden for a new user is getting CGM set up with an appropriate backend.)
> ~S
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Associate Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Chair, Energy Analysis&  Policy Program ~ http://nelson.wisc.edu/eap
Note: I will be on sabbatical for the 2010-2011 academic year.
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110407/e93ed331/attachment.bin>
More information about the cgma-dev
