[cgma-dev] r4723 - cgm/branches/merge-cubit12/geom/OCC
jiangtao_ma at yahoo.com
Thu Apr 7 10:36:31 CDT 2011
Author: janehu
Date: 2011-04-07 10:36:30 -0500 (Thu, 07 Apr 2011)
New Revision: 4723
Added:
cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp_3424
Modified:
Log:
bug fix for handling attrib's string with space case.
Modified: cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp
--- cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp 2011-04-07 15:35:11 UTC (rev 4722)
+++ cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp 2011-04-07 15:36:30 UTC (rev 4723)
@@ -421,22 +421,15 @@
DLIList<double> doubles;
DLIList<int> ints;
int c_num, length;
+ char s;
do {
IS >> c_num; //length of name string
- IS >> buffer;
- if(buffer.length() >= c_num)
- type = buffer.substr( 0, c_num ); //attribute name string
- else
+ IS.get(); //' '
+ type.clear();
+ for(int j = 0; j < c_num; j ++)
- c_num -= buffer.length();
- type.append( buffer );
- do{
- IS >> buffer;
- type.push_back(' ');
- type.append(buffer.substr( 0, c_num ));
- c_num -= (buffer.length() + 1);
- }while (c_num > 0);
+ IS.get(s);
+ type.push_back(s);
CubitString* string_prt = new CubitString(type.c_str());
@@ -447,19 +440,12 @@
for(int i =0; i < length; i++)
IS >> c_num ; //length of each string
- IS >> buffer;
- stringdata = buffer.substr( 0, c_num );
- else
+ IS.get(); //' '
+ stringdata.clear();
- stringdata.append( buffer );
- do{
- IS >> buffer;
- stringdata.push_back(' ');
- stringdata.append(buffer.substr( 0, c_num ));
More information about the cgma-dev
