[cgma-dev] r4699 - cgm/branches/merge-cubit12/test
    jiangtao_ma at yahoo.com
    Thu Mar 31 13:37:03 CDT 2011
Author: janehu
Date: 2011-03-31 13:37:02 -0500 (Thu, 31 Mar 2011)
New Revision: 4699
Modified:
   cgm/branches/merge-cubit12/test/makept.cpp
Log:
Made calling adjustment for cubit12 updates; commented out curve creation from points and tangents test. This new added function in cubit 12 is not quite working yet, and there's a ticket 242 against it right now.
Modified: cgm/branches/merge-cubit12/test/makept.cpp
--- cgm/branches/merge-cubit12/test/makept.cpp	2011-03-31 18:08:27 UTC (rev 4698)
+++ cgm/branches/merge-cubit12/test/makept.cpp	2011-03-31 18:37:02 UTC (rev 4699)
@@ -300,9 +300,9 @@
   //without checking for duplicates, so clean_out first.
   gti->get_free_ref_entities(free_entities);
-  RefVertex* vertex1 = CAST_TO(free_entities.get_and_step(),RefVertex);
-  RefVertex* vertex2 = CAST_TO(free_entities.get_and_step(),RefVertex);
-  RefVertex* vertex3 = CAST_TO(free_entities.get(),RefVertex);
+  RefVertex* vertex1 = CAST_TO(free_entities.step_and_get(),RefVertex);
+  RefVertex* vertex2 = CAST_TO(free_entities.step_and_get(),RefVertex);
+  RefVertex* vertex3 = CAST_TO(free_entities.step_and_get(),RefVertex);
   CubitBoolean is_equal = gti->
 		about_spatially_equal(vertex1,vertex2);
   assert(is_equal == CUBIT_FAILURE);
@@ -319,12 +319,12 @@
   vi = bodies.get()->center_point();
   //first body's bounding box's center point.
-  min.set(16.67, 0, 14.58);
+  min.set(6.67, 0, 14.58);
   assert(vi.distance_between(min) < 0.01 );
   CubitBox box = bodies.get()->bounding_box();
-  min.set(-1.5894,-11.58944, 7.79849);
-  max.set(34.9303,11.58944,21.3615);
+  min.set(-11.5894,-11.58944, 7.79849);
+  max.set(24.9303,11.58944,21.3615);
   test_box.reset(min,max);
   assert(box >= test_box);
   test_box *= 1.01;
@@ -333,7 +333,7 @@
   gti->entity_entity_distance(gti->get_first_ref_volume(), vertex2,vi, vii,d);
   //first body and vertex2 's minimum distance(d) and locations for the minimum.
-  assert(d <11.8607 && d > 11.8606);
+  assert(d <3.64214  && d > 3.64213);
   // test create a Compound body.
   test_bodies.clean_out();
@@ -364,7 +364,7 @@
   vi = CompBody->center_point();
   gti->translate(CompBody,axis);
   vii =CompBody->center_point();
-  assert(vii - vi == axis);
+  assert(axis.about_equal(vii - vi) );
   // After parellel move, center point moved by x (10)
More information about the cgma-dev
