[cgma-dev] help with tarballs
    Mark Miller
    miller86 at llnl.gov
    Thu Mar 24 10:56:09 CDT 2011
This is what I am seeing when I try to make now that I didn't see before yesterday...
+ make -j2
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /scratch/visit/itaps/1.2RC/tools/cgm-10.2.3/missing --run autoconf
 cd . && /bin/sh /scratch/visit/itaps/1.2RC/tools/cgm-10.2.3/missing --run automake-1.11 --foreign
/scratch/visit/itaps/1.2RC/tools/cgm-10.2.3/missing: line 52: automake-1.11: command not found
WARNING: `automake-1.11' is missing on your system.  You should only need it if
         you modified `Makefile.am', `acinclude.m4' or `configure.ac'.
         You might want to install the `Automake' and `Perl' packages.
         Grab them from any GNU archive site.
aclocal.m4:20: warning: this file was generated for autoconf 2.65.
You have another version of autoconf.  It may work, but is not guaranteed to.
If you have problems, you may need to regenerate the build system entirely.
To do so, use the procedure documented by the package, typically `autoreconf'.
configure.ac:10: error: Autoconf version 2.62 or higher is required
aclocal.m4:518: AM_INIT_AUTOMAKE is expanded from...
configure.ac:10: the top level
On Thu, 2011-03-24 at 08:44, Mark Miller wrote:
> In last 24 hours, cgm-nightly tarball has changed such that I cannot
> build without also having autoconf-2.62. In addition, untar dir name
> changed from cgma-10.2.3 to cgm-10.2.3 (missing the 'a'). Ironically,
> however, the version number has apparently not changed.
> What are right URLs to download specific past released versions and
> specific, past nightly versions?
> Mark
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov      urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901    M/W/Th:7-12,2-7 (530)-753-8511
More information about the cgma-dev
