[cgma-dev] r4627 - cgm/trunk/itaps
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Mar 21 17:22:31 CDT 2011
----- Original Message -----
> On 03/21/2011 04:37 PM, Iulian Grindeanu wrote:
> > Thanks Jason,
> > So those extra include folders no longer appear, and no spurious
> > hdf5 link problems appear for me.
> > I have only one other problem, but I do not think it is related to
> > this, it must be something else
> > (test_copymesh fails now, and test_extrudemesh)
> > MeshKit/test/algs> test_copymesh
> > Running test_load_and_copymove ...
> > Running test_copy_quad ...
> > terminate called after throwing an instance of 'MeshKit::Error'
> > what(): CESets.cpp, line 117: Invalid tag data type
> > test_copy_quad: TERMINATED (signal 6)
> > test_copy_quad: TERMINATED (signal 11)
> This is most likely due to changes in r4628
> - jason
Hi Jason,
Yes, you are right;
the "local_tag" type is by default iBase_ENTITY_HANDLE, while later it needs to be iBase_ENTITY_SET_HANDLE
void CopyMesh::do_copy(iMesh::EntitySetHandle set_handle)
assert(transform);
LocalTag local_tag(this->mk_core());
link_expand_sets(expandSets, local_tag);
process_ce_sets(mesh, copySets.sets(), local_tag);
More information about the cgma-dev
