[cgma-dev] r4620 - cgm/trunk
kraftche at cae.wisc.edu
Mon Mar 21 14:22:18 CDT 2011
Author: kraftche
Date: 2011-03-21 14:22:18 -0500 (Mon, 21 Mar 2011)
New Revision: 4620
Modified:
cgm/trunk/configure.ac
Log:
add simple checks that C++ compiler works because autoconf doesn't seem to check that if the compiler is specified by the user via CXX=
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac 2011-03-21 19:16:35 UTC (rev 4619)
+++ cgm/trunk/configure.ac 2011-03-21 19:22:18 UTC (rev 4620)
@@ -22,6 +22,8 @@
AC_C_BIGENDIAN( [], [AM_CPPFLAGS="$AM_CPPFLAGS -DLITTLE_ENDIAN=BYTE_ORDER"] )
FATHOM_COMPILER_FLAGS
+FATHOM_CHECK_CXX_WORKS([], [AC_MSG_ERROR([Cannot build without C++ compiler])])
# Fortran Stuff for ITAPS C bindings
More information about the cgma-dev
