[cgma-dev] r4579 - cgm/branches/merge-cubit12/itaps
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Mar 11 10:28:28 CST 2011
Hello,
It seems that the previous version (4578) on this branch failed the testgeom test.
Iulian
----- Original Message -----
> Author: iulian
> Date: 2011-03-10 19:41:34 -0600 (Thu, 10 Mar 2011)
> New Revision: 4579
> Modified:
> cgm/branches/merge-cubit12/itaps/iBase.h
> cgm/branches/merge-cubit12/itaps/iGeom.h
> cgm/branches/merge-cubit12/itaps/iGeom_CGMA.cc
> cgm/branches/merge-cubit12/itaps/testgeom.cc
> Log:
> changes due to tags interface
> testgeom does not pass yet, but meshkit tests pass
> Still investigating
> Modified: cgm/branches/merge-cubit12/itaps/iBase.h
> --- cgm/branches/merge-cubit12/itaps/iBase.h 2011-03-11 00:44:48 UTC
> (rev 4578)
> +++ cgm/branches/merge-cubit12/itaps/iBase.h 2011-03-11 01:41:34 UTC
> (rev 4579)
> @@ -7,6 +7,11 @@
> #endif
> +#define IBASE_MINENUM(enumName) enumName ## _MIN
> +#define IBASE_MAXENUM(enumName) enumName ## _MAX
> +#define IBASE_NUMENUM(enumName) ((int)IBASE_MAXENUM(enumName) -
> (int)IBASE_MINENUM(enumName) + 1)
> +#define IBASE_INCENUM(enumName,I) (I = (enum enumName)((int)I+1))
> * TYPEDEF'S
> @@ -15,19 +20,22 @@
> typedef struct iBase_EntityHandle_Private* iBase_EntityHandle;
> typedef struct iBase_EntitySetHandle_Private* iBase_EntitySetHandle;
> typedef struct iBase_TagHandle_Private* iBase_TagHandle;
> - typedef void* iBase_EntityIterator;
> - typedef void* iBase_EntityArrIterator;
> + typedef struct iBase_EntityIterator_Private* iBase_EntityIterator;
> + typedef struct iBase_EntityArrIterator_Private*
> * ENTITYTYPE ENUMERATION
> enum iBase_EntityType {
> - iBase_VERTEX = 0,
> + iBase_EntityType_MIN = 0,
> + iBase_VERTEX = iBase_EntityType_MIN,
> iBase_EDGE,
> iBase_FACE,
> iBase_REGION,
> - iBase_ALL_TYPES
> + iBase_ALL_TYPES,
> + iBase_EntityType_MAX = iBase_ALL_TYPES
> @@ -35,13 +43,16 @@
> enum iBase_AdjacencyCost {
> - iBase_UNAVAILABLE = 0, /**< Adjacency information not supported */
> - iBase_ALL_ORDER_1, /**< No more than local mesh traversal required
> - iBase_ALL_ORDER_LOGN, /**< Global tree search */
> - iBase_ALL_ORDER_N, /**< Global exhaustive search */
More information about the cgma-dev
