[cgma-dev] r4568 - cgm/trunk/itaps
James Porter jvporter at wisc.edu
Thu Mar 10 16:41:43 CST 2011
I'll leave that up to the people working on the Cubit 12 branch, since I wouldn't be surprised if there are other changes that need to be merged in, and I don't know how out of sync that branch is.
- Jim
On 03/10/11, Rajeev Jain   wrote:
> How about "merge-cubit12" branch?
> Rajeev
> From: "jvporter at wisc.edu" <jvporter at wisc.edu>
> To: cgma-dev at mcs.anl.gov
> Sent: Thursday, March 10, 2011 13:49:04
> Subject: [cgma-dev] r4568 - cgm/trunk/itaps
> Author: jvporter
> Date: 2011-03-10 13:49:03 -0600 (Thu, 10 Mar 2011)
> New Revision:
>  4568
> Modified:
>    cgm/trunk/itaps/iGeom.h
>    cgm/trunk/itaps/iGeom_CGMA.cc
>    cgm/trunk/itaps/testgeom.cc
> Log:
> Update iGeom's tagging interface to match iMesh's
> Modified: cgm/trunk/itaps/iGeom.h
> --- cgm/trunk/itaps/iGeom.h    2011-03-10 05:50:49 UTC (rev 4567)
> +++ cgm/trunk/itaps/iGeom.h    2011-03-10 19:49:03 UTC (rev 4568)
> @@ -3236,9 +3236,13 @@
>      /**\brief  Set a tag value of arbitrary type on an entity set
> -     * Set a tag value of arbitrary type on an entity set.  Tag data is
> -     * passed as char* type,
> -     * but really represents pointer to arbitrary data.
> +     * Set a tag value of arbitrary type on an entity set. The tag data
> +     * is passed as void*.
>  tag_value_size specifies the size of the memory
> +     * pointed to by tag_value in terms of bytes. Applications are free to
> +     * use this function to set data of any type, not just iBase_BYTES.
> +     * However, in all cases, the size specified by tag_value_size is
> +     * always in terms of bytes.
>       * \param instance iGeom instance handle
>       * \param entity_set_handle Entity set on which tag is being set
>       * \param tag_handle Tag being set on an entity set
> @@ -3248,9 +3252,9 @@
>    void iGeom_setEntSetData( iGeom_Instance instance,
>                              iBase_EntitySetHandle entity_set_handle,
>  iBase_TagHandle tag_handle,
> -                            const char* tag_value,
> -                            int tag_value_size,
> +                            const iBase_TagHandle tag_handle,
> +                            const void* tag_value,
> +                            const int tag_value_size,
>                              int *err );
>      /**\brief  Set a tag value of integer type on an entity set
> @@ -3298,22 +3302,44 @@
>             iBase_EntityHandle tag_value,
>                                int *err );
> +    /**\brief  Set a tag value of entity set handle type on an entity set
> +     * Set a tag value of entity set handle type on an entity set.
> +     * \param instance iGeom instance handle
> +     * \param entity_set Entity set on which tag is being set
> +     * \param tag_handle Tag being set on an entity set
> +     * \param tag_value Tag value being set on entity set
> +     * \param *err Pointer to error type returned from function
> +  void iGeom_setEntSetESHData( iGeom_Instance instance,
> +                               iBase_EntitySetHandle
>  entity_set,
> +                               iBase_TagHandle tag_handle,
> +                               iBase_EntitySetHandle tag_value,
More information about the cgma-dev mailing list
