[cgma-dev] buildbot failure in Fathom on cgm-cubit
    cgma-dev at lists.mcs.anl.gov
    Mon Mar  7 00:50:43 CST 2011
The Fathomatic has detected a failed build of cgm-cubit on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/396
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
make[2]: Nothing to be done for `check'.
Making check in util
make[2]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/util'
Making check in geom
make[2]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom'
Making check in .
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom'
make[3]: Nothing to be done for `check-am'.
Making check in Cholla
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom/Cholla'
make[3]: Nothing to be done for `check'.
Making check in facetbool
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom/facetbool'
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom/facet'
Making check in virtual
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/geom/virtual'
Making check in init
make[2]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/init'
Making check in .
make[2]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build'
Making check in itaps
make[2]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/itaps'
make  check-recursive
make[3]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/itaps'
Making check in .
make[4]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/itaps'
make  chaman  testgeom
make[5]: Entering directory `/disk/itaps-buildslave/cgm-cubit/build/itaps'
g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init    -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
mv -f .deps/chaman.Tpo .deps/chaman.Po
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -R/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin -L/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin  -o chaman chaman.o libiGeom.la -lm
g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o chaman chaman.o  -L/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin ./.libs/libiGeom.a /disk/itaps-buildslave/cgm-cubit/build/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry(char const*, int*)':
iGeom_CGMA.cc:(.text+0x754d): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld: warning: libstdc++.so.5, needed by /home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin/libcubiti19.so, may conflict with libstdc++.so.6
g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init    -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom.o -MD -MP -MF .deps/testgeom.Tpo -c -o testgeom.o testgeom.cc
mv -f .deps/testgeom.Tpo .deps/testgeom.Po
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -R/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin -L/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin  -o testgeom testgeom.o libiGeom.la -lm
g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o testgeom testgeom.o  -L/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin ./.libs/libiGeom.a /disk/itaps-buildslave/cgm-cubit/build/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin
make  check-TESTS
sincerely,
 -The Fathomatic
More information about the cgma-dev
