[cgma-dev] Fw: Re:  Large OCC subtraction time
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Mon Feb 28 12:19:56 CST 2011
--- On Mon, 2/28/11, Jiangtao Hu <jiangtao_ma at yahoo.com> wrote:
Subject: Re: [cgma-dev] Large OCC subtraction time
To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
Cc: meshkit-dev at mcs.anl.gov
Date: Monday, February 28, 2011, 1:18 PM
Hi, Hong-Jun
I've done it by removing io.cpp file then get the new version, it's now working. Thanks.
I see that assygen 7 is doing very slow now, and it's still hanging for Duct no. 2. While I try to debug on it in ddd, I did "run assygen 7" which make 3 = argc in rgg/io.cpp file, it fails to give correct file name for reading. I tried to give m_szInFile="7.inp" or "7" both failed. I am now looking at the code. Can someone also take a look on it?
Thanks.
Jane
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc:
Date: Monday, February 28, 2011, 12:48 PM
I suspect some conflicts between your working version and the one in repository.
How about searching any "<<<" in your "io.cpp" and fix them?
Moreover, I think you also need "--enable-src" to use new MeshKit design algorithms fully.
Hong-Jun
----- Original Message -----
> From: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
> Cc: cgma-dev at mcs.anl.gov
> Sent: Monday, February 28, 2011 11:35:13 AM
> Errors are:
 make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/rgg'
> CXX io.lo
> io.cpp: In member function ‘int CNrgen::ReadInputPhase1()’:
> io.cpp:165: warning: suggest parentheses around ‘&&’ within ‘||’
> io.cpp:172: warning: suggest parentheses around ‘&&’ within ‘||’
> io.cpp: In member function ‘int CNrgen::ReadAndCreate()’:
> io.cpp:528: warning: suggest parentheses around ‘&&’ within ‘||’
> io.cpp:788: error: expected primary-expression before ‘<<’ token
> io.cpp:788: error: expected primary-expression before ‘<’ token
> io.cpp:788: error: expected primary-expression before ‘.’ token
> io.cpp:791: error: expected primary-expression before ‘==’
 token
> io.cpp:791: error: expected primary-expression before ‘==’ token
> io.cpp:791: error: expected primary-expression before ‘=’ token
> io.cpp:793: error: expected primary-expression before ‘if’
> io.cpp:793: error: expected ‘;’ before ‘if’
> io.cpp: In member function ‘int CNrgen::CreateCubitJournal()’:
> io.cpp:833: warning: unused variable ‘i’
> io.cpp:833: warning: unused variable ‘j’
> io.cpp: In member function ‘int CNrgen::CreateOuterCovering()’:
> io.cpp:2017: warning: unused variable ‘p’
> io.cpp: In member function ‘int CNrgen::Subtract_Pins()’:
> io.cpp:2088: error: expected primary-expression before ‘<<’ token
> io.cpp:2088: error: expected primary-expression before ‘.’ token
> io.cpp:2090: error: expected ‘;’ before ‘if’
> io.cpp:2873: error: expected ‘}’ at end of input
> io.cpp:2873: warning: no return statement in function returning
> non-void
> Thanks.
> Jane
> From: Hong-Jun Kim <hongjun at mcs.anl.gov>
> Date: Monday, February 28, 2011, 12:31 PM
> What is your error?
> Hong-Jun
> > From: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> > To: "Hong-Jun Kim" < hongjun at mcs.anl.gov >
> > Sent: Monday, February 28, 2011 11:15:51 AM
> > Ok, now I also updated and make installed
 Lasso, but meshkit still
> > fails to build. Any suggestions.
> > Jane
> > --- On Mon, 2/28/11, Jiangtao Hu < jiangtao_ma at yahoo.com > wrote:
> > From: Jiangtao Hu < jiangtao_ma at yahoo.com >
> > Date: Monday, February 28, 2011, 12:08 PM
> > Hi,
> > I just tried to build
 meshkit, with the following configure:
> > ./configure --enable-debug --with-itaps=/mnt/disk2b/jhu/ddriv
> > it failed on compiling EdgeMesher
> > make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/algs'
> > CXX EdgeMesher.lo
> > In file included from EdgeMesher.cpp:1:
> > EdgeMesher.hpp:16:18: error: iRel.h: No such file or directory
> > EdgeMesher.hpp:40: error: ‘iRel_Instance’ has not been declared
> > EdgeMesher.hpp:40: error: ‘iRel_PairHandle’ has not been declared
> > EdgeMesher.hpp:57: error: ‘iRel_Instance’ does not name a type
> > EdgeMesher.hpp:58: error: ‘iRel_PairHandle’ does not name a type
> > EdgeMesher.cpp:5: error: ‘iRel_Instance’ has not been declared
> > EdgeMesher.cpp:5:
> > EdgeMesher.cpp: In constructor
> > ‘EdgeMesher::EdgeMesher(iGeom_Instance_Private*&,
> > iBase_EntityHandle_Private**, iMesh_Instance_Private*&, int&,
> > int*)’:
> > EdgeMesher.cpp:31: error: ‘assoc’ was not declared in this scope
> > EdgeMesher.cpp:32: error: ‘rel’ was not declared in this scope
> > EdgeMesher.cpp: In member function ‘void EdgeMesher::EdgeMesh()’:
> > EdgeMesher.cpp:120: warning: unused variable ‘NumEntitySet’
> > EdgeMesher.cpp: In member function ‘std::vector<double,
> > std::allocator<double> > EdgeMesher::BiasMeshing()’:
> > EdgeMesher.cpp:203: warning: unused variable ‘err’
> > EdgeMesher.cpp:204: warning: unused variable ‘x’
> > EdgeMesher.cpp:204: warning: unused variable ‘y’
 EdgeMesher.cpp:204: warning: unused variable ‘z’
> > EdgeMesher.cpp:204: warning: unused variable ‘du’
> > std::allocator<double> > EdgeMesher::DualBiasMeshing()’:
> > EdgeMesher.cpp:250: warning: unused variable ‘err’
> > EdgeMesher.cpp:251: warning: unused variable ‘x’
> > EdgeMesher.cpp:251: warning: unused variable ‘y’
> > EdgeMesher.cpp:251: warning: unused variable ‘z’
> > EdgeMesher.cpp:251: warning: unused variable ‘ustart’
> > EdgeMesher.cpp:251: warning: unused variable ‘du’
> > EdgeMesher::RapidSorting(std::vector<double, std::allocator<double>
> > >&, std::vector<double, std::allocator<double> >&, int, int)’:
> > EdgeMesher.cpp:433: warning:
 unused variable ‘x’
> > EdgeMesher.cpp:433: warning: unused variable ‘y’
> > EdgeMesher.cpp:433: warning: unused variable ‘z’
> > EdgeMesher::get_related_entityset(iBase_EntitySetHandle_Private*&)’:
> > EdgeMesher.cpp:591: error: ‘assoc’ was not declared in this scope
> > EdgeMesher.cpp:591: error: ‘rel’ was not declared in this scope
> > EdgeMesher.cpp:591: error: ‘iRel_getEntSetRelation’ was not declared
> > in this scope
> > EdgeMesher.cpp:607: error: ‘iRel_setEntSetRelation’ was not declared
> > in this scope
> > EdgeMesher::ShowCoorData()’:
> > EdgeMesher.cpp:619: error: ‘assoc’ was not declared in this scope
> > EdgeMesher.cpp:619: error: ‘rel’ was not declared in this scope
 EdgeMesher.cpp:619: error: ‘iRel_getEntSetRelation’ was not declared
> > in this scope
> > I've updated cgm, moab and meshkit, and built, installed cgm and
> > moab,
> > did I left something out?
> > Thanks.
> > Jane
> > --- On Sat, 2/26/11, Hong-Jun Kim < hongjun at mcs.anl.gov > wrote:
> > From: Hong-Jun Kim < hongjun at mcs.anl.gov >
> > To: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> > Cc: cgma-dev at mcs.anl.gov , "Rajeev Jain" < jain at mcs.anl.gov >
> > Date: Saturday, February 26, 2011, 12:22 PM
> > In my case of using OCC geometry, attribute updating and removing
> > time
> > take too long.
> > It takes more than import/exporting time of the geometry.
> > Hong-Jun
> > > To: cgma-dev at mcs.anl.gov , "Rajeev Jain" < jain at mcs.anl.gov >
> > > Sent: Saturday, February 26, 2011 11:08:37 AM
> > > Hi, Rajeev:
> > > Thank you for providing the testcase. OCC did have a reputation of
> > > getting much slower with larger models and more operations. I'll
> > > have
> > > a look on Monday to see if there's anything I can do on cgm side
> > > that
> > > can speed it up.
> > > Have a nice weekend!
> > > Jane
> > > --- On Fri, 2/25/11, Rajeev Jain < jain at mcs.anl.gov > wrote:
> > > From: Rajeev Jain < jain at mcs.anl.gov >
> > > Subject: [cgma-dev] Large OCC subtraction time
> > > Date: Friday, February 25, 2011, 4:21 PM
> > > When subtracting 325 pins from a block, OCC takes a lot more time
> > > than
> > > the corresponding ACIS model. I'm attaching the assygen .inp that
> > > can
> > > be run as MeshKit/rgg>assygen 7. This file is for OCC version of
> > > MeshKit. For ACIS change the geometry engine to ACIS in the .inp
> > > file
> > > and run ACIS version.
> > > RGG o/p:
> > > ACIS:
 > > Normal Termination.
> > > Geometry file: 7.sat saved.
> > > Schemes file created: 7.template.jou
> > > Cubit journal file created: 7.jou
> > > Ending at : Fri Feb 25 15:10:31 2011
> > > Elapsed wall clock time: 8 seconds or 0.133333 mins
> > > OCC:
> > > Exported: 327 OCC Bodies to 7.stp
> > > Normal Termination.
> > > Geometry file: 7.stp saved.
> > > Ending at : Fri Feb 25 14:59:51 2011
> > > Elapsed wall clock time: 3173 seconds or 52.8833 mins
> > > The geometry files can be found at
> > > /homes/jain/MeshKit-all/trunk/rgg/test/geometry_parallel_meshing/7.stp
> > > and
 7.sat
> > > Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110228/6266a8fa/attachment.htm>
More information about the cgma-dev
