[cgma-dev] Large OCC subtraction time
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Mon Feb 28 11:35:13 CST 2011
Errors are:
make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/rgg'
  CXX    io.lo
io.cpp: In member function ‘int CNrgen::ReadInputPhase1()’:
io.cpp:165: warning: suggest parentheses around ‘&&’ within ‘||’
io.cpp:172: warning: suggest parentheses around ‘&&’ within ‘||’
io.cpp: In member function ‘int CNrgen::ReadAndCreate()’:
io.cpp:528: warning: suggest parentheses around ‘&&’ within ‘||’
io.cpp:788: error: expected primary-expression before ‘<<’ token
io.cpp:788: error: expected primary-expression before ‘<’ token
io.cpp:788: error: expected primary-expression before ‘.’ token
io.cpp:791: error: expected primary-expression before ‘==’ token
io.cpp:791: error: expected primary-expression before ‘=’ token
io.cpp:793: error: expected primary-expression before ‘if’
io.cpp:793: error: expected ‘;’ before ‘if’
io.cpp: In member function ‘int CNrgen::CreateCubitJournal()’:
io.cpp:833: warning: unused variable ‘i’
io.cpp:833: warning: unused variable ‘j’
io.cpp: In member function ‘int CNrgen::CreateOuterCovering()’:
io.cpp:2017: warning: unused variable ‘p’
io.cpp: In member function ‘int CNrgen::Subtract_Pins()’:
io.cpp:2088: error: expected primary-expression before ‘<<’ token
io.cpp:2088: error: expected primary-expression before ‘<’ token
io.cpp:2088: error: expected primary-expression before ‘.’ token
io.cpp:2090: error: expected ‘;’ before ‘if’
io.cpp:2873: error: expected ‘}’ at end of input
io.cpp:2873: warning: no return statement in function returning non-void
Thanks.
Jane
--- On Mon, 2/28/11, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
Subject: Re: [cgma-dev] Large OCC subtraction time
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: cgma-dev at mcs.anl.gov
Date: Monday, February 28, 2011, 12:31 PM
What is your error?
Hong-Jun
----- Original Message -----
> From: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
> To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> Sent: Monday, February 28, 2011 11:15:51 AM
> Ok, now I also updated and make installed Lasso, but meshkit still
> fails to build. Any suggestions.
> Jane
> --- On Mon, 2/28/11, Jiangtao Hu <jiangtao_ma at yahoo.com> wrote:
> From: Jiangtao Hu <jiangtao_ma at yahoo.com>
> Date: Monday, February 28, 2011, 12:08 PM
> Hi,
> I just tried to build meshkit, with the following configure:
> ./configure --enable-debug --with-itaps=/mnt/disk2b/jhu/ddriv
> it failed on compiling EdgeMesher
> make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/algs'
> CXX EdgeMesher.lo
> In file included from EdgeMesher.cpp:1:
> EdgeMesher.hpp:16:18: error: iRel.h: No such file or directory
> EdgeMesher.hpp:40: error: ‘iRel_Instance’ has not been declared
> EdgeMesher.hpp:40: error: ‘iRel_PairHandle’ has not been declared
> EdgeMesher.hpp:57: error: ‘iRel_Instance’ does not name a type
> EdgeMesher.hpp:58: error: ‘iRel_PairHandle’ does not name a type
> EdgeMesher.cpp:5: error: ‘iRel_Instance’ has not been declared
> EdgeMesher.cpp:5: error: ‘iRel_PairHandle’ has not been declared
> EdgeMesher.cpp: In constructor
> ‘EdgeMesher::EdgeMesher(iGeom_Instance_Private*&,
> iBase_EntityHandle_Private**, iMesh_Instance_Private*&, int&, int*)’:
> EdgeMesher.cpp:31: error: ‘assoc’ was not declared in this scope
> EdgeMesher.cpp:32: error: ‘rel’ was not declared in this scope
> EdgeMesher.cpp: In member function ‘void EdgeMesher::EdgeMesh()’:
> EdgeMesher.cpp:120: warning: unused variable ‘NumEntitySet’
> EdgeMesher.cpp: In member function ‘std::vector<double,
> std::allocator<double> > EdgeMesher::BiasMeshing()’:
> EdgeMesher.cpp:203: warning: unused variable ‘err’
> EdgeMesher.cpp:204: warning: unused variable ‘x’
> EdgeMesher.cpp:204: warning: unused variable ‘y’
> EdgeMesher.cpp:204: warning: unused variable ‘z’
> EdgeMesher.cpp:204: warning: unused variable ‘du’
> std::allocator<double> > EdgeMesher::DualBiasMeshing()’:
> EdgeMesher.cpp:250: warning: unused variable ‘err’
> EdgeMesher.cpp:251: warning: unused variable ‘x’
> EdgeMesher.cpp:251: warning: unused variable ‘y’
> EdgeMesher.cpp:251: warning: unused variable ‘z’
> EdgeMesher.cpp:251: warning: unused variable ‘ustart’
> EdgeMesher.cpp:251: warning: unused variable ‘du’
> EdgeMesher::RapidSorting(std::vector<double, std::allocator<double>
> >&, std::vector<double, std::allocator<double> >&, int, int)’:
> EdgeMesher.cpp:433: warning: unused variable ‘x’
> EdgeMesher.cpp:433: warning: unused variable ‘y’
> EdgeMesher.cpp:433: warning: unused variable ‘z’
> EdgeMesher::get_related_entityset(iBase_EntitySetHandle_Private*&)’:
> EdgeMesher.cpp:591: error: ‘assoc’ was not declared in this scope
> EdgeMesher.cpp:591: error: ‘rel’ was not declared in this scope
> EdgeMesher.cpp:591: error: ‘iRel_getEntSetRelation’ was not declared
> in this scope
> EdgeMesher.cpp:607: error: ‘iRel_setEntSetRelation’ was not declared
> in this scope
> EdgeMesher.cpp: In member function ‘void EdgeMesher::ShowCoorData()’:
> EdgeMesher.cpp:619: error: ‘assoc’ was not declared in this scope
> EdgeMesher.cpp:619: error: ‘rel’ was not declared in this scope
> EdgeMesher.cpp:619: error: ‘iRel_getEntSetRelation’ was not declared
> in this scope
> I've updated cgm, moab and meshkit, and built, installed cgm and moab,
> did I left something out?
> Thanks.
> Jane
> --- On Sat, 2/26/11, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
> From: Hong-Jun Kim <hongjun at mcs.anl.gov>
> Cc: cgma-dev at mcs.anl.gov, "Rajeev Jain" <jain at mcs.anl.gov>
> Date: Saturday, February 26, 2011, 12:22 PM
> In my case of using OCC geometry, attribute updating and removing time
> take too long.
> It takes more than import/exporting time of the geometry.
> Hong-Jun
> > From: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> > To: cgma-dev at mcs.anl.gov , "Rajeev Jain" < jain at mcs.anl.gov >
> > Sent: Saturday, February 26, 2011 11:08:37 AM
> > Hi, Rajeev:
> > Thank you for providing the testcase. OCC did have a reputation of
> > getting much slower with larger models and more operations. I'll
> > have
> > a look on Monday to see if there's anything I can do on cgm side
> > that
> > can speed it up.
> > Have a nice weekend!
> > Jane
> > --- On Fri, 2/25/11, Rajeev Jain < jain at mcs.anl.gov > wrote:
> > From: Rajeev Jain < jain at mcs.anl.gov >
> > Subject: [cgma-dev] Large OCC subtraction time
> > Date: Friday, February 25, 2011, 4:21 PM
> > When subtracting 325 pins from a block, OCC takes a lot more time
> > than
> > the corresponding ACIS model. I'm attaching the assygen .inp that
> > can
> > be run as MeshKit/rgg>assygen 7. This file is for OCC version of
> > MeshKit. For ACIS change the geometry engine to ACIS in the .inp
> > file
> > and run ACIS version.
> > RGG o/p:
> > ACIS:
> > Normal Termination.
> > Geometry file: 7.sat saved.
> > Schemes file created: 7.template.jou
> > Cubit journal file created: 7.jou
> > Ending at : Fri Feb 25 15:10:31 2011
> > Elapsed wall clock time: 8 seconds or 0.133333 mins
> > OCC:
> > Exported: 327 OCC Bodies to 7.stp
> > Normal Termination.
> > Geometry file: 7.stp saved.
> > Ending at : Fri Feb 25 14:59:51 2011
> > Elapsed wall clock time: 3173 seconds or 52.8833 mins
> > The geometry files can be found at
> > /homes/jain/MeshKit-all/trunk/rgg/test/geometry_parallel_meshing/7.stp
> > and 7.sat
> > Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110228/1ad7d79f/attachment.htm>
More information about the cgma-dev
