[cgma-dev] Large OCC subtraction time
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Mon Feb 28 11:08:27 CST 2011
I just tried to build meshkit, with the following configure:
./configure --enable-debug --with-itaps=/mnt/disk2b/jhu/ddriv
it failed on compiling EdgeMesher
make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/algs'
  CXX    EdgeMesher.lo
In file included from EdgeMesher.cpp:1:
EdgeMesher.hpp:16:18: error: iRel.h: No such file or directory
EdgeMesher.hpp:40: error: ‘iRel_Instance’ has not been declared
EdgeMesher.hpp:40: error: ‘iRel_PairHandle’ has not been declared
EdgeMesher.hpp:57: error: ‘iRel_Instance’ does not name a type
EdgeMesher.hpp:58: error: ‘iRel_PairHandle’ does not name a type
EdgeMesher.cpp:5: error: ‘iRel_Instance’ has not been declared
EdgeMesher.cpp:5: error: ‘iRel_PairHandle’ has not been declared
EdgeMesher.cpp: In constructor ‘EdgeMesher::EdgeMesher(iGeom_Instance_Private*&, iBase_EntityHandle_Private**, iMesh_Instance_Private*&, int&, int*)’:
EdgeMesher.cpp:31: error: ‘assoc’ was not declared in this scope
EdgeMesher.cpp:32: error: ‘rel’ was not declared in this scope
EdgeMesher.cpp: In member function ‘void EdgeMesher::EdgeMesh()’:
EdgeMesher.cpp:120: warning: unused variable ‘NumEntitySet’
EdgeMesher.cpp: In member function ‘std::vector<double, std::allocator<double> > EdgeMesher::BiasMeshing()’:
EdgeMesher.cpp:203: warning: unused variable ‘err’
EdgeMesher.cpp:204: warning: unused variable ‘x’
EdgeMesher.cpp:204: warning: unused variable ‘y’
EdgeMesher.cpp:204: warning: unused variable ‘z’
EdgeMesher.cpp:204: warning: unused variable ‘du’
EdgeMesher.cpp: In member function ‘std::vector<double, std::allocator<double> > EdgeMesher::DualBiasMeshing()’:
EdgeMesher.cpp:250: warning: unused variable ‘err’
EdgeMesher.cpp:251: warning: unused variable ‘x’
EdgeMesher.cpp:251: warning: unused variable ‘y’
EdgeMesher.cpp:251: warning: unused variable ‘z’
EdgeMesher.cpp:251: warning: unused variable ‘ustart’
EdgeMesher.cpp:251: warning: unused variable ‘du’
EdgeMesher.cpp: In member function ‘void EdgeMesher::RapidSorting(std::vector<double, std::allocator<double> >&, std::vector<double, std::allocator<double> >&, int, int)’:
EdgeMesher.cpp:433: warning: unused variable ‘x’
EdgeMesher.cpp:433: warning: unused variable ‘y’
EdgeMesher.cpp:433: warning: unused variable ‘z’
EdgeMesher.cpp: In member function ‘void EdgeMesher::get_related_entityset(iBase_EntitySetHandle_Private*&)’:
EdgeMesher.cpp:591: error: ‘assoc’ was not declared in this scope
EdgeMesher.cpp:591: error: ‘rel’ was not declared in this scope
EdgeMesher.cpp:591: error: ‘iRel_getEntSetRelation’ was not declared in this scope
EdgeMesher.cpp:607: error: ‘iRel_setEntSetRelation’ was not declared in this scope
EdgeMesher.cpp: In member function ‘void EdgeMesher::ShowCoorData()’:
EdgeMesher.cpp:619: error: ‘assoc’ was not declared in this scope
EdgeMesher.cpp:619: error: ‘rel’ was not declared in this scope
EdgeMesher.cpp:619: error: ‘iRel_getEntSetRelation’ was not declared in this scope
I've updated cgm, moab and meshkit, and built, installed cgm and moab, did I left something out?
Thanks.
Jane
--- On Sat, 2/26/11, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
Subject: Re: [cgma-dev] Large OCC subtraction time
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: cgma-dev at mcs.anl.gov, "Rajeev Jain" <jain at mcs.anl.gov>
Date: Saturday, February 26, 2011, 12:22 PM
In my case of using OCC geometry, attribute updating and removing time take too long.
It takes more than import/exporting time of the geometry.
Hong-Jun
----- Original Message -----
> From: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
> To: cgma-dev at mcs.anl.gov, "Rajeev Jain" <jain at mcs.anl.gov>
> Sent: Saturday, February 26, 2011 11:08:37 AM
> Hi, Rajeev:
> Thank you for providing the testcase. OCC did have a reputation of
> getting much slower with larger models and more operations. I'll have
> a look on Monday to see if there's anything I can do on cgm side that
> can speed it up.
> Have a nice weekend!
> Jane
> --- On Fri, 2/25/11, Rajeev Jain <jain at mcs.anl.gov> wrote:
> From: Rajeev Jain <jain at mcs.anl.gov>
> Subject: [cgma-dev] Large OCC subtraction time
> Date: Friday, February 25, 2011, 4:21 PM
> When subtracting 325 pins from a block, OCC takes a lot more time than
> the corresponding ACIS model. I'm attaching the assygen .inp that can
> be run as MeshKit/rgg>assygen 7. This file is for OCC version of
> MeshKit. For ACIS change the geometry engine to ACIS in the .inp file
> and run ACIS version.
> RGG o/p:
> ACIS:
> Normal Termination.
> Geometry file: 7.sat saved.
> Schemes file created: 7.template.jou
> Cubit journal file created: 7.jou
> Ending at : Fri Feb 25 15:10:31 2011
> Elapsed wall clock time: 8 seconds or 0.133333 mins
> OCC:
> Exported: 327 OCC Bodies to 7.stp
> Normal Termination.
> Geometry file: 7.stp saved.
> Ending at : Fri Feb 25 14:59:51 2011
> Elapsed wall clock time: 3173 seconds or 52.8833 mins
> The geometry files can be found at
> /homes/jain/MeshKit-all/trunk/rgg/test/geometry_parallel_meshing/7.stp
> and 7.sat
> Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110228/e2bff81a/attachment.htm>
More information about the cgma-dev
