[cgma-dev] Large OCC subtraction time
    Rajeev Jain
    jain at mcs.anl.gov
    Fri Feb 25 15:21:03 CST 2011
When subtracting 325 pins from a block, OCC takes a lot more time than the
corresponding ACIS model. I'm attaching the assygen .inp that can be run as
MeshKit/rgg>assygen 7.  This file is for OCC version of MeshKit. For ACIS change
the geometry engine to ACIS in the .inp file and run ACIS version.
RGG o/p:
ACIS:
Normal Termination.
Geometry file: 7.sat saved.
Schemes file created: 7.template.jou
Cubit journal file created: 7.jou
Ending at : Fri Feb 25 15:10:31 2011
Elapsed wall clock time: 8 seconds or 0.133333 mins
OCC:
Exported: 327 OCC Bodies to 7.stp
 Normal Termination.
Geometry file: 7.stp saved.
Ending at : Fri Feb 25 14:59:51 2011
Elapsed wall clock time: 3173 seconds or 52.8833 mins
The geometry files can be found at
/homes/jain/MeshKit-all/trunk/rgg/test/geometry_parallel_meshing/7.stp and 7.sat
Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110225/b1762eac/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110225/b1762eac/attachment.obj>
More information about the cgma-dev
