[cgma-dev] r4495 - cgm/branches/merge-cubit12/geom/OCC
    jiangtao_ma at yahoo.com
    Tue Feb 15 13:11:11 CST 2011
Author: janehu
Date: 2011-02-15 13:11:11 -0600 (Tue, 15 Feb 2011)
New Revision: 4495
Modified:
   cgm/branches/merge-cubit12/geom/OCC/OCCLoop.cpp
   cgm/branches/merge-cubit12/geom/OCC/OCCLoop.hpp
   cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp
   cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.hpp
Log:
Added split_curve function for merge_cubit12 specific requirement.
Added update_OCC_entity function in OCCLoop for split curve operation.
Added  a check for clean_up_slivers opetion for split_body with vectors.
Consolidate function split_shape_by_location for both split body and split curve funtions
Modified: cgm/branches/merge-cubit12/geom/OCC/OCCLoop.cpp
--- cgm/branches/merge-cubit12/geom/OCC/OCCLoop.cpp	2011-02-15 16:59:02 UTC (rev 4494)
+++ cgm/branches/merge-cubit12/geom/OCC/OCCLoop.cpp	2011-02-15 19:11:11 UTC (rev 4495)
@@ -36,6 +36,8 @@
 #include "BRepBuilderAPI_GTransform.hxx"
 #include "BRepBuilderAPI_ModifyShape.hxx"
 #include "BRepAlgoAPI_BooleanOperation.hxx"
+#include "LocOpe_SplitShape.hxx"
+#include "BRepTools_WireExplorer.hxx"
 // ********** END CUBIT INCLUDES           **********
 // ********** BEGIN STATIC DECLARATIONS    **********
@@ -267,3 +269,40 @@
   return CUBIT_SUCCESS;
+// Function: TopoDS_Shape level function to update the core Loop
+//           for split Boolean operation of the body.
+// Author: Jane Hu
+CubitStatus OCCLoop::update_OCC_entity(TopoDS_Wire & old_loop,
+                                       LocOpe_SplitShape* sp)
+  TopTools_ListOfShape shapes;
+  shapes.Assign(sp->DescendantShapes(old_loop));
+  assert(shapes.Extent() == 1);
+  TopoDS_Shape new_loop = shapes.First();
+  TopoDS_Shape shape_edge;
+  //set curves
+  BRepTools_WireExplorer Ex;
+  for(Ex.Init(old_loop); Ex.More();Ex.Next())
+    TopoDS_Edge edge = Ex.Current();
+    shapes.Assign(sp->DescendantShapes(edge));
+    if(shapes.Extent() > 1)
+      //update all attributes first.
+      TopTools_ListIteratorOfListOfShape it;
+      it.Initialize(shapes);
+      for(; it.More(); it.Next())
+        shape_edge = it.Value();
+        OCCQueryEngine::instance()->copy_attributes(edge, shape_edge);
+      OCCQueryEngine::instance()->update_OCC_map(edge, shape_edge);
More information about the cgma-dev
