[cgma-dev] buildbot failure in Fathom on cgm-occ
Tim Tautges tautges at mcs.anl.gov
Mon Feb 14 08:52:46 CST 2011
This is the commit I made over the weekend removing a few enum values - Jane, I suggest tacking those enums on the end
of that enum, instead of in the middle.  that is assuming, though, that there isn't any code hardwired to the size of
the enum.
- tim
On 02/14/2011 12:33 AM, cgma-dev at lists.mcs.anl.gov wrote:
> The Fathomatic has detected a failed build of cgm-occ on Fathom.
> Full details are available at:
>   http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/388
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: gnep
> Build Reason: The Nightly scheduler named 'nightly' triggered this build
> Build Source Stamp: None
> Blamelist:
> BUILD FAILED: failed compile
> LOG EXCERPT:
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c SubSurface.cpp -o SubSurface.o
> mv -f .deps/SubSurface.Tpo .deps/SubSurface.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla   -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c -o TDVGFacetOwner.lo TDVGFacetOwner.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c TDVGFacetOwner.cpp -o TDVGFacetOwner.o
> mv -f .deps/TDVGFacetOwner.Tpo .deps/TDVGFacetOwner.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla   -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c -o TDVGFacetSplit.lo TDVGFacetSplit.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c TDVGFacetSplit.cpp -o TDVGFacetSplit.o
> mv -f .deps/TDVGFacetSplit.Tpo .deps/TDVGFacetSplit.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla   -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c -o VirtualQueryEngine.lo VirtualQueryEngine.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c VirtualQueryEngine.cpp -o VirtualQueryEngine.o
> VirtualQueryEngine.cpp: In member function 'virtual CubitStatus VirtualQueryEngine::get_graphics(Surface*, int&, int&, int&, GMem*, short unsigned int, double, double) const':
> VirtualQueryEngine.cpp:201: warning: format '%p' expects type 'void*', but argument 3 has type 'Surface*'
> VirtualQueryEngine.cpp:201: warning: format '%p' expects type 'void*', but argument 7 has type 'GMem*'
> VirtualQueryEngine.cpp: In member function 'virtual CubitStatus VirtualQueryEngine::entity_entity_distance(GeometryEntity*, GeometryEntity*, CubitVector&, CubitVector&, double&)':
> VirtualQueryEngine.cpp:1396: warning: unused variable 'gqe2'
> mv -f .deps/VirtualQueryEngine.Tpo .deps/VirtualQueryEngine.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla   -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c -o VirtualImprintTool.lo VirtualImprintTool.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/facet -I../../geom/Cholla -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c VirtualImprintTool.cpp -o VirtualImprintTool.o
> mv -f .deps/VirtualImprintTool.Tpo .deps/VirtualImprintTool.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcubit_virtual.la  AllocMemManagersVirtual.lo CACompositeVG.lo CAPartitionVG.lo CAVirtualVG.lo CollapseAngleTool.lo CompositeAttrib.lo CompositeBody.lo CompositeCoEdge.lo CompositeCoSurf.lo CompositeCurve.lo CompositeEngine.lo CompositeGeom.lo CompositeLoop.lo CompositeLump.lo CompositePoint.lo CompositeShell.lo CompositeSurface.lo CompositeTool.lo CompSurfFacets.lo Faceter.lo FaceterFacetData.lo FaceterPointData.lo FacetProjectTool.lo HiddenEntitySet.lo ImprintBoundaryTool.lo ImprintLineSegment.lo ImprintPointData.lo PartitionBody.lo PartitionCoEdge.lo PartitionCoSurf.lo PartitionCurve.lo PartitionEngine.lo PartitionEntity.lo PartitionLoop.lo PartitionLump.lo PartitionLumpImprint.lo PartitionPoint.lo PartitionShell.lo PartitionSurface.lo PartitionTool.lo PartPTCurve.lo PartSurfFacetTool.lo PST_Data.lo SegmentedCurve.lo SubCurve.lo SubEntitySet.lo SubSurface.lo TDVGFacetOwner.lo TDV
GF
>   acetSplit.lo VirtualQueryEngine.lo VirtualImprintTool.lo   -lm
> mkdir .libs
> ar cru .libs/libcubit_virtual.a  AllocMemManagersVirtual.o CACompositeVG.o CAPartitionVG.o CAVirtualVG.o CollapseAngleTool.o CompositeAttrib.o CompositeBody.o CompositeCoEdge.o CompositeCoSurf.o CompositeCurve.o CompositeEngine.o CompositeGeom.o CompositeLoop.o CompositeLump.o CompositePoint.o CompositeShell.o CompositeSurface.o CompositeTool.o CompSurfFacets.o Faceter.o FaceterFacetData.o FaceterPointData.o FacetProjectTool.o HiddenEntitySet.o ImprintBoundaryTool.o ImprintLineSegment.o ImprintPointData.o PartitionBody.o PartitionCoEdge.o PartitionCoSurf.o PartitionCurve.o PartitionEngine.o PartitionEntity.o PartitionLoop.o PartitionLump.o PartitionLumpImprint.o PartitionPoint.o PartitionShell.o PartitionSurface.o PartitionTool.o PartPTCurve.o PartSurfFacetTool.o PST_Data.o SegmentedCurve.o SubCurve.o SubEntitySet.o SubSurface.o TDVGFacetOwner.o TDVGFacetSplit.o VirtualQueryEngine.o VirtualImprintTool.o
> ranlib .libs/libcubit_virtual.a
> creating libcubit_virtual.la
> (cd .libs&&  rm -f libcubit_virtual.la&&  ln -s ../libcubit_virtual.la libcubit_virtual.la)
> Making all in OCC
> make[4]: Entering directory `/disk/itaps-buildslave/cgm-occ/build/geom/OCC'
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c -o OCCShapeAttributeSet.lo OCCShapeAttributeSet.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c OCCShapeAttributeSet.cpp -o OCCShapeAttributeSet.o
> mv -f .deps/OCCShapeAttributeSet.Tpo .deps/OCCShapeAttributeSet.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c -o OCCAttribSet.lo OCCAttribSet.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c OCCAttribSet.cpp -o OCCAttribSet.o
> OCCAttribSet.cpp: In static member function 'static CubitStatus OCCAttribSet::get_attributes(TopoDS_Shape&, DLIList<CubitSimpleAttrib*>&)':
> OCCAttribSet.cpp:405: warning: unused variable 'string'
> mv -f .deps/OCCAttribSet.Tpo .deps/OCCAttribSet.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c -o OCCBody.lo OCCBody.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c OCCBody.cpp -o OCCBody.o
> mv -f .deps/OCCBody.Tpo .deps/OCCBody.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c -o OCCCoEdge.lo OCCCoEdge.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c OCCCoEdge.cpp -o OCCCoEdge.o
> mv -f .deps/OCCCoEdge.Tpo .deps/OCCCoEdge.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c -o OCCCoFace.lo OCCCoFace.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c OCCCoFace.cpp -o OCCCoFace.o
> mv -f .deps/OCCCoFace.Tpo .deps/OCCCoFace.Plo
> /bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c -o OCCCurve.lo OCCCurve.cpp
>   g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c OCCCurve.cpp -o OCCCurve.o
> OCCCurve.cpp: In member function 'virtual GeometryType OCCCurve::geometry_type()':
> OCCCurve.cpp:613: error: 'BSPLINE_CURVE_TYPE' was not declared in this scope
> OCCCurve.cpp: In member function 'void OCCCurve::adjust_periodic_parameter(double&)':
> OCCCurve.cpp:880: warning: unused variable 'edge_range'
> sincerely,
>   -The Fathomatic
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
