[cgma-dev] buildbot failure in Fathom on cgm-shared
    James Porter
    jvporter at wisc.edu
    Mon Feb  7 13:33:21 CST 2011
Looks like this was just an intermittent problem on gnep, since the
tests succeed now.
- Jim
On Mon, 2011-02-07 at 00:01 -0600, cgma-dev at lists.mcs.anl.gov wrote:
> The Fathomatic has detected a failed build of cgm-shared on Fathom.
> Full details are available at:
>  http://gnep.mcs.anl.gov:8010/builders/cgm-shared/builds/368
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: gnep
> Build Reason: The Nightly scheduler named 'cgm-shared-nightly' triggered this build
> Build Source Stamp: None
> Blamelist:
> BUILD FAILED: failed configure
> LOG EXCERPT:
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC
> checking if gcc PIC flag -fPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> configure: creating libtool
> appending configuration tag "CXX" to libtool
> checking for ld used by g++... /usr/bin/ld -m elf_x86_64
> checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
> checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking for g++ option to produce PIC... -fPIC
> checking if g++ PIC flag -fPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> (cached) (cached) checking how to hardcode library paths into programs... immediate
> appending configuration tag "F77" to libtool
> checking for g77 option to produce PIC... -fPIC
> checking if g77 PIC flag -fPIC works... yes
> checking if g77 static flag -static works... yes
> checking if g77 supports -c -o file.o... yes
> checking whether the g77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking for a sed that does not truncate output... /bin/sed
> checking whether byte ordering is bigendian... no
> checking for known C compilers... GNU
> checking for known compiler/OS combinations... GNU:x86_64
> checking for known c++ compilers... GNU
> checking how to get verbose linking output from gfortran... -v
> checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -lgfortranbegin -lgfortran -lm
> checking for dummy main to link with Fortran libraries... none
> checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
> checking for C++-standard library in std:: namespace... yes
> checking for C++-standard I/O in std:: namespace... yes
> checking if C++ template definitions should be included... yes
> configure: error: /home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64: not a directory.
> sincerely,
>  -The Fathomatic
More information about the cgma-dev
