[cgma-dev] buildbot failure in Fathom on cgm-occ
    cgma-dev at lists.mcs.anl.gov
    Wed Feb  2 00:34:49 CST 2011
The Fathomatic has detected a failed build of cgm-occ on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/376
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o testgeom_occ testgeom_occ-testgeom.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ./.libs/libiGeom.a /disk/itaps-buildslave/cgm-occ/build/.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/
 sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lpthread -ldl -lm
 -Wl,--rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib -Wl,--rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry(char const*, int*)':
iGeom_CGMA.cc:(.text+0x761d): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
make  check-TESTS
make[5]: Entering directory `/disk/itaps-buildslave/cgm-occ/build/itaps'
Using default input file: ./../test/LeverArm.brep
Geometry engine set to: OpenCascade 6.3
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: ERROR: Problem getting number of parents in gentityset_test.
  Error code: 22
  Error desc: Num_hops argument not yet supported.
  At        : testgeom.cc:713
Failure
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
Success
   shutdown: Success
TSTT TEST SUMMARY:
   Number Tests:           9
   Number Successful:      8
   Number Not Implemented: 0
   Number Failed:          1
FAIL: testgeom_occ
1 of 1 tests failed
sincerely,
 -The Fathomatic
More information about the cgma-dev
