[cgma-dev] r4469 - cgm/trunk/geom/OCC
    jiangtao_ma at yahoo.com
    Tue Jan 25 13:33:29 CST 2011
Author: janehu
Date: 2011-01-25 13:33:28 -0600 (Tue, 25 Jan 2011)
New Revision: 4469
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Change back to not create sliver curves and surfaces. Otherwise, the model do show some sliver edges created which are not expected.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-01-24 20:16:57 UTC (rev 4468)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2011-01-25 19:33:28 UTC (rev 4469)
@@ -1968,7 +1968,7 @@
   double area = myProps.Mass();
   double tol = get_sme_resabs_tolerance();
   if(area < tol * tol)
-    PRINT_WARNING("Generated a sliver surface. \n");
+    return CUBIT_FAILURE;
   if (!OCCMap->IsBound(aShape))
@@ -2169,7 +2169,7 @@
   BRepGProp::LinearProperties(aShape, myProps);
   double length =  myProps.Mass();
   if(length < get_sme_resabs_tolerance())
-    PRINT_WARNING("Generated a sliver curve. \n");
More information about the cgma-dev
