[cgma-dev] buildbot failure in Fathom on cgm-occ
    cgma-dev at lists.mcs.anl.gov
    Mon Jan 24 00:30:03 CST 2011
The Fathomatic has detected a failed build of cgm-occ on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/367
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
OCCCurve.cpp: In member function 'void OCCCurve::adjust_periodic_parameter(double&)':
OCCCurve.cpp:880: warning: unused variable 'edge_range'
OCCCurve.cpp: In member function 'virtual CubitStatus OCCCurve::closest_point(const CubitVector&, CubitVector&, CubitVector*, CubitVector*, double*)':
OCCCurve.cpp:440: warning: 'pparam' may be used uninitialized in this function
mv -f .deps/OCCCurve.Tpo .deps/OCCCurve.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c -o OCCLoop.lo OCCLoop.cpp
 g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c OCCLoop.cpp -o OCCLoop.o
mv -f .deps/OCCLoop.Tpo .deps/OCCLoop.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c -o OCCLump.lo OCCLump.cpp
 g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c OCCLump.cpp -o OCCLump.o
mv -f .deps/OCCLump.Tpo .deps/OCCLump.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo OCCModifyEngine.cpp
 g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c OCCModifyEngine.cpp -o OCCModifyEngine.o
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::imprint(DLIList<BodySM*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const':
OCCModifyEngine.cpp:3025: warning: unused variable 'volume'
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::intersect(BodySM*, DLIList<BodySM*>&, DLIList<BodySM*>&, bool) const':
OCCModifyEngine.cpp:3711: warning: unused variable 'from_body'
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::tweak_move(DLIList<Surface*>&, const CubitVector&, DLIList<BodySM*>&, CubitBoolean, CubitBoolean) const':
OCCModifyEngine.cpp:7211: warning: suggest parentheses around assignment used as truth value
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::tweak_move(DLIList<Curve*>&, const CubitVector&, DLIList<BodySM*>&, CubitBoolean, CubitBoolean) const':
OCCModifyEngine.cpp:7327: warning: suggest parentheses around assignment used as truth value
OCCModifyEngine.cpp: In member function 'CubitStatus OCCModifyEngine::sort_curves(DLIList<Curve*>, DLIList<DLIList<TopoDS_Edge*>*>&) const':
OCCModifyEngine.cpp:802: warning: 'new_end' may be used uninitialized in this function
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::webcut(DLIList<BodySM*>&, const BodySM*, DLIList<BodySM*>&, bool) const':
OCCModifyEngine.cpp:4899: warning: 'body' is used uninitialized in this function
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::sweep_along_curve(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, DLIList<Curve*>&, double, int, bool, Surface*, BodySM*) const':
OCCModifyEngine.cpp:4740: warning: 'type' may be used uninitialized in this function
OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::sweep_translational(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, const CubitVector&, double, int, bool, bool, Surface*, BodySM*) const':
OCCModifyEngine.cpp:4281: warning: 'Cornertype' may be used uninitialized in this function
OCCModifyEngine.cpp: In member function 'CubitStatus OCCModifyEngine::tweak_fillet(Curve*, double, double, BodySM*&, CubitBoolean, CubitBoolean, CubitBoolean)':
OCCModifyEngine.cpp:6792: warning: 's' may be used uninitialized in this function
mv -f .deps/OCCModifyEngine.Tpo .deps/OCCModifyEngine.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c -o OCCPoint.lo OCCPoint.cpp
 g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c OCCPoint.cpp -o OCCPoint.o
mv -f .deps/OCCPoint.Tpo .deps/OCCPoint.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c -o OCCQueryEngine.lo OCCQueryEngine.cpp
 g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c OCCQueryEngine.cpp -o OCCQueryEngine.o
OCCQueryEngine.cpp: In member function 'CubitStatus OCCQueryEngine::write_topology(const char*, const char*, DLIList<OCCBody*>&, DLIList<OCCSurface*>&, DLIList<OCCCurve*>&, DLIList<OCCPoint*>&)':
OCCQueryEngine.cpp:1121: warning: unused variable 'count'
OCCQueryEngine.cpp: In member function 'CubitBoolean OCCQueryEngine::Write(const TopoDS_Shape&, char*&, int&, bool, TDF_Label)':
OCCQueryEngine.cpp:1368: warning: deprecated conversion from string constant to 'char*'
OCCQueryEngine.cpp: In member function 'CubitBoolean OCCQueryEngine::Read(TopoDS_Shape&, const char*, int, TDF_Label)':
OCCQueryEngine.cpp:1417: warning: deprecated conversion from string constant to 'char*'
OCCQueryEngine.cpp: In member function 'Surface* OCCQueryEngine::populate_topology_bridge(const TopoDS_Face&, CubitBoolean)':
OCCQueryEngine.cpp:1971: error: 'PRINT_WARING' was not declared in this scope
OCCQueryEngine.cpp: In member function 'virtual CubitStatus OCCQueryEngine::delete_solid_model_entities(BodySM*) const':
OCCQueryEngine.cpp:2362: warning: unused variable 'stat'
OCCQueryEngine.cpp: In member function 'int OCCQueryEngine::update_OCC_map(TopoDS_Shape&, TopoDS_Shape&)':
OCCQueryEngine.cpp:3425: warning: unused variable 'shape'
OCCQueryEngine.cpp:3431: warning: unused variable 'shape'
sincerely,
 -The Fathomatic
More information about the cgma-dev
